Calling all buschur racing downpipe installer
Old Jul 19, 2014 | 05:22 PM
evo9powerr's Avatar
I installed my buschur racing downpipe like 2-3 weeks ago and have never been able to stop the exhaust leak of it .. With my map 02 dump it never seal .. Ive bolt it and unbolt it like 4 times with no luck ... Im tired already i paid 320$ supposely for the best downpipe out there to have this kind of problems .. Cant stop this leak .. What you guys think
Old Jul 19, 2014 | 05:45 PM
211Ratsbud's Avatar
Search quickly I posted in a thread fitment remedies and quirks with the o2 housing. .. it's designed to fit a specific sized housing
Old Jul 19, 2014 | 05:59 PM
evo9powerr's Avatar
Will be alot easier if you juat put a link of the thread .. Ive never learn to search good here
Old Jul 19, 2014 | 06:22 PM
211Ratsbud's Avatar
https://www.evolutionm.net/forums/sh...e=2&styleid=28
Old Jul 23, 2014 | 12:48 PM
efaustin's Avatar
Im running buschur 02 housing and 3inch DP i put a three inch gasket in between the DP and o2 housing i also put a layer of copper permatex on both sides of the gasket and i have no leaks.
Old Jul 24, 2014 | 02:26 AM
slow gst's Avatar
There's a thread somewhere on here where someone used I think it was a mazda rx8 exhaust gasket and it sealed it up good. I couldn't find it but I will keep searching. My BR downpipe has a very small leak as well and I've tried just about everything, donut gasket/no donut gasket, 3 inch gasket, no gaskets, doubled up 3 inch gasket, 3 inch gasket with permatex, the permatex is whats on there now and like I said it's a very small leak. I'm done trying to fix it..
Old Sep 21, 2014 | 06:18 PM
snamtrac's Avatar
I think I have the same issue. I've tried doubling up on vibrant gaskets and now just tried the Mazda rx8 gasket. I'm still getting a leak. I'm thinking of going back to a donut style gasket. I have the jmf o2 housing.
Did any of you find a solution?
Old Sep 21, 2014 | 11:00 PM
NHazz's Avatar
Veteran: Air Force
What permatex are you guys using? The copper rtv high temp silicone stuff is what you want, I used it by itself on my Buschur DP and it stopped leaking. Any gasket method combined with that ultra high temp stuff should work if applied correctly.
Old Sep 22, 2014 | 07:00 AM
snamtrac's Avatar
I was using the copper high temp that was rated to 700F. Not sure how hot that area is reaching though. When I last took it apart it appeared as if the copper rtv got a little runny on the flange.
If your o2 is leaking at idle it may be because you do not have a divided o2 housing gasket. MAP and Jmfab both make these gaskets.
Old Sep 23, 2014 | 08:16 PM
xXANCHORMONXx's Avatar
I got a 3 bolt copper gasket from Vato Zone and trimmed the center.
Worked nicely
Old Sep 25, 2014 | 06:47 AM
211Ratsbud's Avatar
You guys that are still leaking I bet your dp is not seating on your o2 housing all the way. I didn't need a gasket once I solved that.
All covered in the thread I linked.
You should remove both pieces to adjust the fitment. The machined face on the o2 must fit all the way to the down pipe
Old Sep 27, 2014 | 12:44 AM
detroit pistins's Avatar
Its also possible that some may have used the stock o2 gasket with the aftermarket o2 dump and the leak is actually coming thru the dump tube.
Old Sep 27, 2014 | 01:34 PM
evo7_8u's Avatar
I had the same issue with my Megan Racing down pipe and o2 Housing . I just put some approved hightemp sealant on the gasket and it hasn't leaked yet.
Old Oct 30, 2014 | 12:34 PM
Swedin's Avatar
I had to 'massage' my BR down pipe to fit the BR o2 housing, don't use a gasket and still no leaks. after I 'massaged' my DP I actually comes over the collar on the o2 housing and makes a great seal! try that possibly?!
Old Nov 5, 2014 | 09:27 AM
David Buschur's Avatar
Don't call and ask us or send me a PM, that would be too easy................
I'm assuming with the 02 housing dump you have the company that built it doesn't have the extended lip on it like the stock one or the 02 housing that we sell has. That means you are going to need a good gasket in there, the extended lip on the stock housing/our 02 housing makes it so you don't need one.
jdmauto
Aug 6, 2016 06:49 PM
Insanity Evo
Dec 2, 2015 09:08 AM
ralliart360
Dec 8, 2014 03:36 PM
milab21
Jul 28, 2014 07:29 AM
master c
Oct 20, 2013 04:06 PM
