threw a cel code p0401 EGR insufficient flow error
Old Mar 6, 2008 | 09:20 PM
  #121
Erik@MIL.SPEC's Avatar
EGR valve hose off = MAJOR boost leak. Don't ask me how I know
Old Mar 9, 2008 | 09:07 AM
  #122
Evo8Emperor's Avatar
What if your going with a aftermarket manifold and theres no place for the EGR to be hooked back up ?
Im throwing a p0403 Exhaust Gas Recirculation Malfunction.
Would anyone have any idea what this would mean ?
Old Mar 9, 2008 | 09:11 AM
  #123
20Grockit's Avatar
theres a way to disable egr valve and accessories. im not exactly sure how. im sure if you do some searching you can find it on here.
Old Mar 9, 2008 | 09:54 AM
  #124
Ohh nice ty at least i know now im not that much of an ***. I guess ill have to do some serious searching.
I have one other question not petaining to this topic really but would anyone know why i wouldnt be getting any fuel trim readings in mitsulogger along with o2 censor feedback trim.
I was thinking the obvious o2 censor gone bad. If to much gas hits a o2 censor dont they like foul out ? or no ?
Old Mar 9, 2008 | 11:18 AM
  #125
Evoryder's Avatar
check the mitsu xml file to make sure it's enabled which should say, "y" after the word "logged" ..
As far as the diabling the EGR check. Here is the info, be careful with what you disable. (From Aktivematrix.com)
Add this address(universal to all ecu's) to the bottom of your "evo7base" save it. eg
<table name="ECU_PEREPHERY" category="Misc" address="faa" type="1D" level="4" scaling="Hex16"/>
<table name="ECU_PEREPHERY1" category="Misc" address="fba" type="1D" level="4" scaling="Hex16"/>
<table name="ECU_PEREPHERY2" category="Misc" address="fca" type="1D" level="4" scaling="Hex16"/>
<table name="ECU_PEREPHERY3" category="Misc" address="fda" type="1D" level="4" scaling="Hex16"/>
The settings:
If you want to disable EVAP set ECU Perephery2 = 0xCFDF
If you want to disable EGR set ECU Perephery2 = 0xEDDF
If you want to disable EVAP and EGR set ECU Perephery2 = 0xCDDF
The factory default for ECU Perephery2 = 0xEFDF ....just copy and paste.
Old Mar 9, 2008 | 11:56 AM
  #126
raiceboi697's Avatar
well it sure would be cool if i didnt throw this code once i put my new intake manifold on, fingers crossed with this new ecuflash tuning idea
Old Mar 9, 2008 | 12:16 PM
  #127
Evoryder's Avatar
it will work
thank Bez_basini +Malibujack and others...
Old Mar 9, 2008 | 02:01 PM
  #128
Thanks evo ryder for the info. I wasnt having to much luck searching for it.
Old Mar 9, 2008 | 02:11 PM
  #129
That info was found on the aktive matrix site right ? I cant copy the writing that u pasted in so i was going to try and copy it off that site. Not sure where you found it though on aktive matrix.
Old Mar 9, 2008 | 02:33 PM
  #130
Excuse my ignorance but what is the evap ? And what is it for ?
Old Mar 9, 2008 | 03:46 PM
  #131
Ok seems like all went well. I got it all pasted into my rom definition and had no problems opening it up again. I checked my xml file for mitsulogger also and i had all the "y"'s in the right place where u said.
Im not getting any o2 censor readings in anything which i am now assuming is my main problem. I have scan tech and under o2 censor one i am only reading .020 volts and censor 2 im getting 0 volts.
Old Mar 9, 2008 | 03:54 PM
  #132
Evoryder's Avatar
page 1 - 10
http://www.aktivematrix.com/forum/vi...5812fcb65668dc
fuel system...venting gases/fumes fuel tank
Old Mar 9, 2008 | 03:55 PM
  #133
Evoryder's Avatar
when was the last time you replaced it?
Old Mar 9, 2008 | 04:05 PM
  #134
The car only has 23000k miles on it and hasnt been drivin on the road in two years. But after the mods i did i had a very poor map and my injectors were dirty. So the car was running really rich and i ended up fouling a few sets of plugs trying to get it dialed in.
Its still running rich and i was thinking the excess gas ruined the o2 censors. Or is that not possible ?
Old Mar 9, 2008 | 04:09 PM
  #135
on the link in my sig is a video of my car at idle i took this morning for someone helping me with it now on evom.
