Will Code P0107 prevent the car from starting?
Old Sep 11, 2014 | 05:20 PM
han74j's Avatar
I pulled 2 codes on the car, P0107 which is Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem. The barometric circuit that is attached to the OE intake pipe, its off on my car I have stand alone HKS F-con.... Will that prevent the car from starting?
Old Sep 12, 2014 | 12:07 PM
han74j's Avatar
I pull the MAF on, car pulled 0 code, car still did not start. So assuming that the code did not cause the car not to start.
Old Sep 12, 2014 | 12:33 PM
Ev0ikon's Avatar
Who did the initial instalaltion/tune that F-con ECU for you? Is it converted to Speed Density?
Old Sep 12, 2014 | 12:40 PM
han74j's Avatar
Its on speed density.
Old Sep 12, 2014 | 01:04 PM
Ev0ikon's Avatar
Did you pull that code using the HKS software and their serial cable or just a regular OBD scanner?
Old Sep 12, 2014 | 01:41 PM
han74j's Avatar
Originally Posted by ev0ikon
did you pull that code using the hks software and their serial cable or just a regular obd scanner?
odbii
Old Sep 12, 2014 | 05:45 PM
Bhsj13's Avatar
did it start up fine before? maybe your MAP sensor is faulty? imo, you should go to a oem ecu and retune for speed density. tscomptuned does tunes for many people on here and could probably get you set up.
Old Sep 12, 2014 | 05:54 PM
han74j's Avatar
I dont think its a turning issue, the last time the car really started was about 5-6 years ago. This post is piggy back on my other post on why my car isn't starting up.
I don't have a MAP sensor =)
jerrymldz
Jun 16, 2017 02:40 PM
christianreed91
Sep 11, 2016 09:12 PM
Eveyevo
Sep 21, 2014 04:28 AM
evo9nuuub
Jun 28, 2010 02:00 PM
Nesiop
Aug 12, 2009 09:38 AM
