View Poll Results: At what mileage was your transfer case replaced?
Zero to 1,000 miles
0%
1,000 miles to 5,000 miles
23.53%
5,000 miles to 10,000 miles
23.53%
10,000 miles to 15,000 miles
23.53%
Transfer case replaced more than once
5.88%
Yes, Covered by warranty
35.29%
No, Not covered by warranty
17.65%
Multiple Choice Poll. Voters: 17. You may not vote on this poll
Replaced Your transfer Case?
Please respond ONLY if your transfer case has been replaced. Note that you should select two choices. One for mileage and one for warranty or not. Thanks.
Here is a soundclip of a bad transfer case...
You need QUICKTIME in order to hear it...
http://userweb.suscom.net/~dtdelollis/noise1.3gp
I realize these things are not the strongest drivetrain parts in the world, but how are you breaking them? I have done countless clutch drops on my 90 talon AWD and never broken a thing. Given, I never had any problems with wheelhop. Still have a stock clutch in my EVO, so hard launches are kind of out of the question. Are they just going out on you, or are you doing something to break them?
-Ryan-
-Ryan-
Hi,
There appears to be a manufacture's defect in a small number (so far). Plus a few have been broken on sticky tracks and aftermarket clutches. The 1G DSM's ususally blows diffs when horsepower and "shock" exceeds the drivetrain's capacity to absorb both. And the Evo drivetrain is substantially different from the DSM's. (like a different zip code
Speedlimit...
)Speedlimit...
I haven't had any problems at all in 31k miles.
Although when I switched to redline products at 15k. I did notice ALOT of metal shavings on the magnetic drain plug.
I've read numerous reports that this front/center diff might also be shimmed to closely.
If thats the case, its probably best to be gentle with the drive train post break in period until everything gets broken in more.
I dont launch my car either which probably helps.
FWIW..
-Rob
FWIW..
-Rob
when mine was going I had the stock fluid in it.... after I put redline and it quite'd it up big time and then I went and had the dealer replace it and they put the stock fluid back in.... that is what i'm running now
