P0442 after tb install
Old Oct 8, 2014 | 05:06 PM
selp's Avatar
I'm hoping this would be a install error or leak.
I removed a 70mm (Full Blown) TB and installed a 65mm ported stocker TB using the stock gasket. I do have a Rev3 intake manifold ported to 70mm, but TB didn't seem to leak.
It was not until the second day of using the car that the code appeared. Note that I did see rpm fluctuations especially when clutching in when coming to a stop. Ranging from 1k to 1.5k.
The egr sensor on the manifold has been blocked, so it was a straight fwd install.
I know the p0442 is typically the gas cap or the evaporative system. Could it be a coincidence, or the gas cap or evaporative system is bad? Or the TB has a leak causing issues?
Thanks!
Old Oct 9, 2014 | 09:33 AM
AJCaron12's Avatar
A defective or aftermarket throttle body will not set evaporative system diagnostic trouble codes.
Old Oct 10, 2014 | 09:13 PM
selp's Avatar
How about a leak due to the TB?
I assume the RPM fluctuations are caused by the TB having a leak? or could it be the evaporative system?
Old Oct 12, 2014 | 01:32 PM
AJCaron12's Avatar
The evap system has nothing to do with your throttle body. It sounds like you may have 2 separate issues; P0442, which will need to be diagnosed, and an engine idle problem that needs to be diagnosed. I believe that the two are not linked.
Evo_Goodness
Mar 21, 2018 11:28 AM
GeorgeP
Northeast Region
May 18, 2017 07:12 PM
ayazlb
Dec 21, 2015 10:32 AM
Myszkewicz
Jun 29, 2009 02:19 AM
staatz
22
Nov 29, 2008 11:05 AM
