Tolerance on Plastigage for Main & Rod Bearings Clearance
Hi, what is the Tolerance on Plastigage for Main & Rod Bearings Clearance for a standard bearings & the Torque (ft-lb) for doing it?
Thanks
Thanks
torque it as if you were doing final assembly. Tolerance depends on what tolerance you're shooting for, whether it be OEM or tighter, or looser. However, plasti-gauge isn't exactly accurate..
Measure everything up and post your results. .0015-.002 is fine for the rod big end. The mains are ok a little looser, up to .0025.
elhalisf
Oct 28, 2018 11:50 AM
newbieEVO8
Jun 18, 2012 09:04 AM
konstantinosIX
Jan 19, 2010 10:03 AM
