Transmission failures
Old Mar 9, 2015 | 09:37 AM
mxmatt15's Avatar
I can't seem to find a concrete answer about the 5th gear grinding issues that is common on the 5spds. If I were to do a rebuild what can I do to prevent it from happening again? I don't think the grind is from user error, so if I rebuild with new synchros it will likely happen again after given time. What can be done to prevent this issue from reoccurring?
Old Mar 9, 2015 | 09:59 AM
llDemonll's Avatar
Unless you're tracking the car, or the clutch is adjusted improperly, this isn't a common issue AFAIK
Old Mar 9, 2015 | 10:19 AM
Ev0ikon's Avatar
This. Drag kills.
SupraSkylineSTI
26
Apr 21, 2010 11:45 PM
Jasil
May 30, 2005 04:54 PM
Noize
15
Apr 28, 2005 10:24 AM
Thoe99
Jun 4, 2004 09:13 AM
