Evo IX: Compression Test Results (125, 137, 137, 140)?
My brother is currently looking to purchase an Evolution IX and a local tuning shop just ran a compression test and the results are 125, 137, 137, 140. Cylinder 1 is a bit worrisome but the shop said it could be buildup in the valve and could be cleaned by running e85? Note that the car has a protune for e85 but I think it was running mainly only a separate 91 map.
He's getting the leakdown test done right now but just wanted to throw these numbers out there to see what you all think?
Per the Evolution IX manual, the standard value is 145 PSI and the minimum limit is 92 PSI (these are lower than the VIII's). Just want to make sure the 15 PSI variance isn't something that could cause him the need to shell out money for a rebuild in the upcoming year or two.
Leak it down. Compression test is kind of generic; your really just looking for a variance in values. As cylinder 1 is low and its tuned for e85... My guess is that it was poorly tuned which in turn hurt cylinder 1. Per leak down you cohld be buying an expensive project for yourself.
alien1979
For Sale - Wheels / Tires / Suspension / Brakes
Apr 2, 2012 04:58 AM
05blue8
Apr 11, 2009 06:51 PM
