CT9A ACD question
Old Mar 13, 2015 | 06:28 AM
Zombie Killer's Avatar
CT9A ACD question
Coming from the X I know that the ACD pump is known to fail under as yet undetermined causes (tech bulletin out on it, limited dealership support; ticking time bomb that seems to MOSTLY affect USDM MY08 GSRs from my research). I also know that the VIII is also prone to failure (cause?)....is the IX the same? Is the ACD pump identical in all aspects/years/models of the CT9A?
Old Mar 13, 2015 | 06:34 AM
ronaldo9's Avatar
VIII and IX pump are the same.
Old Mar 13, 2015 | 06:43 AM
So both prone to failure. Damn. No GOOD fix?
Old Mar 13, 2015 | 08:18 AM
ronaldo9's Avatar
Put silicone around the edges of anywhere you think water may enter. Or relocate to the trunk.
Old Mar 13, 2015 | 08:19 AM
Ev0ikon's Avatar
A good fix is to move it to the trunk - out of the element.
Old Mar 13, 2015 | 08:26 AM
Is there a known cause? Corrosion ticking time bomb?
Old Mar 13, 2015 | 08:29 AM
ronaldo9's Avatar
Corrosion killed my last pump. So i try not drive in salt covered roads.
Old Mar 13, 2015 | 08:30 AM
Dallas J's Avatar
Veteran: Army
From what Ive seen most of the failures occur in areas that salt the road. That's why most of the ones that need to be disassembled are extremely corroded. I wouldn't worry about it failing, but you can always get rebuild kit on order early if you're worried.
Another option would be a weather resistant bag like they use in the RC world.. Haven't seen it done but would likely help keep water off the pump.
06MREvo
For Sale - Part Outs
34
Nov 18, 2014 01:05 PM
NOMIEZVR4
Oct 18, 2013 01:28 PM
DubsE46
10
Dec 30, 2011 04:48 PM
rsboy
Dec 1, 2004 08:13 PM
