Evo 9 No Start.....Stumped
Old Mar 14, 2015 | 05:24 PM
snazzyseth's Avatar
hey just installed a motor into my car (was running and driving prior to removal)
go to give it the initial start, and it cranks but won't kick heres what i have diag-ed,
No Spark No, Fuel pump prime...
1. All fuses checked/grounds cleaned
2. 12v to fuel pump fuse, connector at pump top hat and if relay is hit with power the pump kicks on
3. 12v to coil packs
4. NO power to crank and cam sensors
the grounds i have installed are for engine harness (only ones i removed)
1. neg battery cable ground (mini battery grounded the cable to old battery tray mounting hole by the trans mount)
2. transmission housing ground
3. cam sensor ground on the sensor housing
4. intake manifold to body (by strut tower brace)
any help is greatly appreciated, and once problem is solved i will update to give this thread some closure
Thanks guys,
Seth.
Old Mar 15, 2015 | 02:43 AM
StreetThisEvo's Avatar
Your cam sensors may be switched (reversed). They are different. I had a similar issue awhile back
Old Mar 15, 2015 | 12:41 PM
snazzyseth's Avatar
I'll give that a shot.
Old Mar 17, 2015 | 02:21 PM
snazzyseth's Avatar
Ok cam sensors are in the right spots
Ground tested to harness side of sensor and both cam and crank sensors are ground (dvm to battery positive and ground lead to sensors ground pin=12v)
Any other ideas?
Old Mar 17, 2015 | 08:01 PM
snazzyseth's Avatar
hooked scanner up to pull any codes that were present and there was no communication...
am i looking at a faulty ECU?
Old Mar 17, 2015 | 09:06 PM
barneyb's Avatar
It was working before so I say no. Put the battery on a charger until full charge and then check fuses.
Old Mar 19, 2015 | 06:08 AM
snazzyseth's Avatar
Update.
Notice while attempting to crank the check engine light does not illuminate with key on.
Also ecu plug c-119 has all the sensors I'm not getting power to on the harness
1.)Pin 45 I belive is rpm signal I get 8v
2.) ground to earth pins(x2) show they are grounded when tested.
3.) pin 60 is 12v constant from battery and receives now power when tested, but when hit with voltage from power probe the Relays go crazy, but cel comes on I can communicate with scanner to ecu and maf,crank,cam etc all get 5volts
Jsiebert
May 26, 2014 12:41 PM
Evo3573
Jul 13, 2013 05:18 PM
geevolution
Dec 31, 2009 05:31 PM
Thomasevo
Oct 1, 2009 02:51 PM
