FP and CBRD no longer have bolt on turbos - Whats next?
#76
The ATP turbos sound like on paper a good option but they really need to get a couple turbos on cars. No one is going to be a guinea pig for over $2k. I know they have them on other cars but that's just not apples-apples.
With the 3B and Green BB out of circulation I'll be waiting till next winter to see what fills the void.
#79
I'm not sure but I think I stumbled upon something....will MAP be selling Blouch Dominator Stock Frame Turbos or have these long been around? I know STI guys have had the Blouch "Dominator" turbos for a while now but I've never seen/heard of any evos with them:
http://www.maperformance.com/blouch-performance-turbo/
This XTR2.0 is the one that interests me the most.
Mitsubishi Evolution 9 Dominator 1.0XT Stock Frame Turbo | EVO9-DOM-1.0XT - Price: $1695.00
The 1.0XT Dominator Turbo is not to be messed with. Available with a journal bearing center section and crafted around the stock frame Evo 9 turbo, this quick-spooling Evolution turbocharger will transform your sleepy little stock Evo into a AWD street ripping monster. Capable of 470hp, this pairs great with your bolt-on's and will make you look good while doing it.
Blouch has been one of the biggest names in forced induction. Specializing in stock frame Evo 8/9 turbo's, they have experience across a wide array of makes and models, each making more power and torque than the next. Not only can you trust in Blouch for great Mitsubishi turbochargers, but top notch customer service is there to handle all your need
Mitsubishi Evolution 9 Dominator 1.0XTR Ball Bearing Turbo | EVO9-DOM-1.0XTR - Price: $2250.00
Blouch Performance Evo 9 Turbo Upgrade
Blouch's 1.0XTR Dominator Turbo is your go to option for ball bearing Evo 9 performance turbo's. Built around the stock frame Evo 9 turbo, this no nonsense Evolution turbocharger will possess your car, turning your beloved Evo into a AWD street ripping demon. Capable of 470hp, this turbo plays well with bolt-on's and will make you look like a boss while doing it.
If you haven't heard of Blouch Performance Turbo, you must have been living under a rock. BPT has worked to become one of the biggest names in forced induction. Specializing in stock frame Evo 8/9 turbo's, they have experience across a wide array of makes and models. Not only can you trust in Blouch for great Mitsubishi turbochargers, but BPT's top notch customer service is there to handle all your needs
Evo 9 Dominator 2.0XT Ball Bearing Stock Frame Turbo | EVO9-DOM-2.0XT - Price: $2350.00
Imagine you're out on the track, pushing your Evolution to it's limits. Suddenly you're being passed by cars left and right. What do they have that you dont? Horsepower and torque. Stomping on the gas does nothing, downshifting helps a little, but before you know it you're in dead last and getting laughed at by your peers.
What do you do now? Head over to MAPerformance and look up Blouch Performance Turbochargers. Right away you've made the best decision possible. MAPerformance has the lowest parts on the web, guaranteed. Blouch has the best Evo 9 turbochargers on the market. Two reasons right away why you've made the right decision.
A Blouch XTR2.0 Evo Turbo is capable of making 570hp, which is more than enough power to send your foes packing up and heading home.
#80
We certainly will be selling them! We were going to post up everything in this thread later on today about it!
#89
Ask and you shall receive!!!
For the Evo 8/9 Turbochargers here are the flow rates and HP Rating (Crank HP on Pump Gas).
Dom 1.0XT and 1.0XTR flow 47-48lbs per min
Inducer Wheel Size: 62.5mm
Exducer Wheel Size: 54.3mm
HP Rating: 480CHP
Dom 2.0XTR flows 56-57lbs per min
HP Rating: 570CHP
Dom 3.0XTR flows 64-65 lbs per min
Inducer Wheel Size: 67mm
Exducer Wheel Size: 60mm
HP Rating: 650CHP
For the Evo 10 Turbochargers here are the flow rates and HP Rating (Crank HP on Pump Gas).
Dom 1.0XT and XTR flow 47-48lbs per min
HP Rating: 480CHP
Dom 2.0XT and XTR flow 56-57lbs per min
HP Rating: 570CHP
Dom 3.0XTR flows 65-66lbs per min
HP Rating: 660CHP
We are absolutely ecstatic to carry the Blouch brand here at MAP and help them get these turbos out into your hands!
HP Rating: 480CHP
HP Rating: 570CHP
HP Rating: 650CHP
HP Rating: 480CHP
HP Rating: 570CHP
HP Rating: 660CHP
#90
HP Rating: 650CHP
HP Rating: 650CHP
*Edit just noticed the name has an R in it which would mean it's ball bearing.
