Engine rebuild
Old Mar 20, 2015 | 09:43 AM
mr2rr's Avatar
Engine rebuild
I have been researching on this forum about engine rebuild but most people built their motor for 500+ hps gained. However, I just want to build it for my daily drive not that aggressive but little upgrade than stock setup. Anyone recommends what products as far as pistons or other necessary parts should I be replacing or upgrading while the motor is out? Thank you.
Old Mar 20, 2015 | 10:49 AM
LetsGetThisDone's Avatar
wiseco pistons 9.0:1 compresion, eagle rods, ACL tri-metals. GSC S1 cams or similar, like kelford 264's or 268's. A mild valve spring upgrade, like GSC 5039's or 5040's. Head studs, main studs. All the proper machine work, and you'll have a stout block that will easily max out the stock turbo, or any turbo capable of 500lbft of torque.
Old Mar 20, 2015 | 02:51 PM
mr2rr's Avatar
You think should I go with the stock size on pistons?
Old Mar 20, 2015 | 02:53 PM
You would need to have a machine shop measure the bore for roundness and taper to make an intelligent decision on whether to stay standard size, or go with an over sized piston and bore the cylinder accordingly.
Old Mar 20, 2015 | 09:21 PM
mr2rr's Avatar
Cool, thank you.
philamthebest
Jul 18, 2012 03:02 PM
Mauricio Evo IV
Jun 9, 2011 08:10 AM
metaphysical
109
Aug 4, 2004 08:42 AM
TURBOit
Lancer Engine Tech
Mar 3, 2004 05:15 PM
zlancer
Lancer Engine Tech
Jun 15, 2002 02:02 AM
