HKS 264 and 272 mix setup
Old Oct 16, 2010 | 04:01 AM
  #31
albalushi85's Avatar
Originally Posted by 04AWDTURBOEVO
Here is my set-up with HKS's 264i and 272e Cams.
Fidanza Cam Gears, both set very negative.
The little Cams can hold the power all the way past Redline, . And, also notice the mid power, .
264i/272e with Cam Gears. Good choice.
They have allways made power for me, even on stock 9.8 Turbo, .
Tuning, also very important, as some have mention.
Hi bro,
I have the same cams with Vishnu adjustable cam gears....can you please advice me with thier settings...I have them at -6i/-1e which somehow not running fast and my torque is very low
Old Oct 16, 2010 | 04:06 AM
  #32
Originally Posted by puckadog
with my 264/272, sprockets(-3) my torque went from 285 (without cams) to 324. that's probably what you're feeling jj008
Hi,
You gained lots of torque by only retarding both in and ex by 3... I would love to try that with my 264/272 cams.
what if the car didnt start after retarding both in,ex by 3.....what does it indicate to
thnx
Old Oct 16, 2010 | 05:15 AM
  #33
sparky's Avatar
The problem with jumpstarting these older threads is that many of the members who posted on it have since moved on to other pastures. This may have happened with "puckadog" who may not ever answer your question as he hasn't posted on these forums for over a year. He's probably driving a Skoda. God bless him.
Try a -2 intake/-3 exhaust setting on those 264/272 cams. This is close to the Vishnu setting of -3/-3 but, with a slightly more advanced intake opening. It will still idle smooth and have good topend but should improve midrange torque slightly. Your current -6 setting on the intake cam is way too retarded which results in a lack of midrange torque and response.
Old Oct 17, 2010 | 12:24 AM
  #34
Thanks alot for the advice bro, but if i am not wronge that I have tried -2i/-3e but the car didnt start but this doesnt meen I should not try it again.
Hope that I get my car power back because its so week that a stock evo8 catchs up. Tuning is recomended after the cams settins right!!!
Regards,
Balucci
Old Oct 17, 2010 | 12:28 AM
  #35
jameswwt's Avatar
Hi Guys,
anyone knows what is the ideal gsc s2 cams setting in order to have a great low and mid end torque?
1 tooth Advance on Intake and 0 on Exh +1/0???
Thanks
Old Oct 18, 2010 | 07:58 AM
  #36
jameswwt's Avatar
Originally Posted by jameswwt
Hi Guys,
Thanks
Anyone to share???
evolved8 bs
Nov 29, 2015 09:55 PM
nickracer9
11
Apr 6, 2005 08:39 AM
Evo8tuning
Mar 3, 2005 09:29 AM
DSMBRETT
Dec 1, 2004 07:16 PM
Bonefish
Jan 13, 2004 05:03 PM
