Compression test readings
Old Mar 25, 2015 | 08:43 PM
mr2rr's Avatar
I did compression test on my evo today, need some inputs about its health. I bought it 4 months ago with high mileage 195K miles. I thought I did compression test first before thinking about rebuilding it. Here is the reading see what you guys think if I should rebuild or keep running it. Thank you.
Dry: Cylinder #1: 170, #2: 195, #3: 195, #4: 180
Wet: #1: 185, #2: 200. #3: 205, #4: 190
Old Mar 27, 2015 | 05:30 PM
mr2rr's Avatar
no one has any ideas?
Old Mar 27, 2015 | 06:40 PM
IzzyRS's Avatar
Not that big of a difference between em, run it for a bit and start putting money aside for a rebuild I guess.
Old Mar 27, 2015 | 07:16 PM
lostsoulsevo's Avatar
Those numbers are great for 195k miles
Old Mar 28, 2015 | 07:39 PM
ray3328's Avatar
Numbers look good. I wouldn't change anything unless your planning to run big power and then I would have it rebuilt but not because of the numbers but because it's got 195k miles.
Old Mar 29, 2015 | 08:30 PM
mr2rr's Avatar
Yea, the numbers I think they are looking good but because of the the high mileage I don't know if I should do the rebuild or just wait until it is completely worn.
Old Apr 21, 2015 | 10:47 AM
mrm95's Avatar
Wow those compression numbers are pretty spot on. Especially with 195k miles. that is amazing!! Has the car been stock its entire life? I would not be worrying about a rebuild.
Old Apr 21, 2015 | 12:04 PM
LetsGetThisDone's Avatar
Yea, those numbers on awesome. Nothing to worry about there.
Old Apr 21, 2015 | 12:54 PM
sujinX's Avatar
i like to go by the rule of 'if its not broke dont fix it'
i'd hold off and save until it lets go.
Old Apr 22, 2015 | 09:13 AM
mr2rr's Avatar
Yup, I will run with it for now, however, my clutch just went out guess what it was still using the stock OEM clutch. This car was pretty much never been modified just like the previous owner said. Therefore, I will change out all the important seals and timing belt just a peace of mind. Thank you guys.
Old Apr 22, 2015 | 11:05 AM
mrm95's Avatar
+1
4b11slayer
Sep 30, 2016 07:26 AM
DuBBzEvo27
Jun 29, 2015 10:00 PM
robyn402
Aug 13, 2010 07:07 AM
dambikeracer
57
Mar 14, 2010 07:43 PM
Sloop
May 13, 2004 11:31 AM
