Looking for check on mod list for first tune
With a 3 inch DP it looks like I will also need to replace the front lower arm brace?
Another stupid question: Before getting a tune can an EBC be installed and have it work with the stock tune?
I see a fuel pump but no injectors? Just a downpipe? No mid/muffler? Personally, I'm not a fan of Megan products. Spend a few extra bucks and get something decent like ETS if you want it to last. You might want to consider the Cajun Power T-Bolt clamp kit and the Mil.Spec throttle shaft seals. I'm going to bet $1 that your OEM ones are already leaking.
Otherwise seems like a decent starting point. Most of the power will come from the tune for sure. You won't be disappointed.
like the OP im betting i have a tiny leak there, and i'm betting it's causing the idle bounce i sometimes experience
Jonno99
May 30, 2015 04:33 PM
