Rear outer CV joint removal and install question...
Old Jun 3, 2015 | 07:52 AM
Technical10's Avatar
I will start off with that the axles that I am working with were originally together and never apart so no chance of anything being awry. I did have outer CV boots to replace as both were torn from a foreign object. I did remove the axles from the car to work on them.
The question that I have yet to find an answer, and yes I did search everything from forums, tech manuals, talking to axle companies, and even general pictures of people replacing CV joints---- nothing comes close to answering my question.
The question is that I knocked off the outer CV joint on the rear axle and I did not notice any retention clips at all when I popped the first one off. I looked inside the CV assembly and nothing and furthermore the axle came out without much fuss. Then I did the same for the second one with the same result and this time I really paid attention to see if there was a clip.... nothing.
So that is the question.... has anyone removed the rear axle bar out of the outer CV joint and is it simply a slight interference fit, no clip even though there is a groove for a retaining ring?
binky
34
Jun 25, 2017 06:53 PM
powerstroke
Jan 30, 2017 07:38 AM
fsc0224
Nov 28, 2012 09:00 AM
FX11
May 12, 2009 08:04 PM
travelsize420
Lancer Troubleshooting
Jul 6, 2006 10:51 AM
