Anyone use the FP Xona Rotor turbos yet?
Old Oct 6, 2015 | 12:21 AM
  #46
Migsubishi's Avatar
Man I can't decide between the xona 82-67 or the 95-67, the only difference between the two is the compressor wheel as they share the same exhaust wheel and everything else. Fp states that they have a 500rpm spool difference but 100hp between the two. Is 100hp worth the 500rpm trade off? Decisions.... What do you guys think?
Fp also states that the Xona 8267 is about 500rpm laggier than the HTA86 and the 9567 is obviously a thousand rpm laggier.
Old Oct 6, 2015 | 08:44 AM
  #47
Gsrwanted137's Avatar
I mean at 720hp++ I would keep the spooling earlier if i can. Im running an 82/67 with tial 1.06 housing, i dont get the spool till 4500rpm ish. I miss the early spool life lol
Old Oct 6, 2015 | 02:18 PM
  #48
Migsubishi's Avatar
Why so big on the housing? I'm going to stick with the .82 Tial
I just don't know if I would even notice a 500rpm difference between the two turbos. I would definitely notice it between the Hta86 and the Xona 9567.
Edit : Okay, the Xona 9567 is the direct replacement for the old FP 3794. That turbo didn't spool till around 5k on on my old 2.3l stroker. I'm going to opt for the 8267 which replaced the FP 6466HTZ and stuff it into a Tial .82 a/r exhaust housing.
Old Oct 7, 2015 | 04:36 PM
  #49
jake33's Avatar
Yeah the 8267 is really a bad mother ****er lol i beleive the unit flows 90lbs/min
Old Oct 7, 2015 | 07:15 PM
  #50
MrLith's Avatar
Hahahaha I don't think so, the first two digits are FP's rating for the max lb/min flow from the turbo - so 8267 is an 82lb/min compressor with a 67mm turbine.
Old Oct 7, 2015 | 07:47 PM
  #51
Migsubishi's Avatar
Fp has been under rating their turbos forever, for every flow/hp rating there is someone who made more than those turbos are rated for.
Old Oct 12, 2015 | 11:27 AM
  #52
JohnBradley's Avatar
They revised all of their numbering systems when the switched to the bespoke center sections. The 82-67 is more like the 3794 than a 3586. The 3586 is the 78-64 in the new nomenclature.
Old Oct 13, 2015 | 02:52 AM
  #53
Migsubishi's Avatar
Although I know the Xona will prove more reliable in the long run, I think I'm going to run a precision turbo. A friend brought some things to my attention about the size of the turbos and what housings are available for the best spool. For the first time ever since stock, I'm going twin scroll!
Old Oct 15, 2015 | 12:35 AM
  #54
Malaxa's Avatar
I do not want to question the quality of products(XONA). Contest seriousness of approach. I think it's unprofessional offering turbochargers without full data-sheets. Dialogue with their officials, is similar to the discussion of a stall in a vegetable market.
Old Oct 15, 2015 | 09:31 AM
  #55
LetsGetThisDone's Avatar
They tell you what it flows. What more do you want? I feel like you want more info than you actually need.
Old Oct 15, 2015 | 01:17 PM
  #56
EvoIX89's Avatar
I agree^ knowing the Compressor wheel dimensions, turbine wheel size, and flow rate is a lot of info. It is nice to have a compressor map for comparison with other turbos, but the info they provide Is enough I think.
Old Oct 15, 2015 | 01:47 PM
  #57
And having a compressor map also really requires knowing exactly what your engine flows at given rpm's to utilize the information on the compressor map...
Old Oct 15, 2015 | 07:34 PM
  #58
Malaxa's Avatar
Garrett offer without any problem, for each turbine, this information. All the information you need if you want to work scientifically, professionally. What pressure develops maximum flow? What is the schedule compressor, but turbine? What is the island of efficiency? ...
For example:
GT3582R (2)
Attached Thumbnails Anyone use the FP Xona Rotor turbos yet?-1.jpg   Anyone use the FP Xona Rotor turbos yet?-2.jpg   Anyone use the FP Xona Rotor turbos yet?-3.gif
Old Oct 15, 2015 | 10:07 PM
  #59
Migsubishi's Avatar
Hey, then leave FP alone and go buy a Garrett and leave this thread to the people running or interested in info from people who run the Xona turbos!
Old Oct 16, 2015 | 07:01 AM
  #60
Malaxa's Avatar
I do not know which is your occupation, but I'm not gather folklore.
I am an engineer and I see things correctly.
I understand you and I need to see a proper documentation in order to have a professional approach. I understand that there can be discussion below is a forum for enthusiasts.
I did not ever think that if a product require proper documentation, someone could think like you.
