No intake or diverter valve sound...
Old Jun 13, 2015 | 04:38 PM
griz's Avatar
Need help diagnosing a problem: I have an open cone filter and used to clearly hear my intake/diverter valve and I can no longer hear it. Compressor wheel spins freely with no play, and I checked for leaks and pretty sure all I have is a very small one by the throttle body. What am I missing?
Old Jun 13, 2015 | 05:09 PM
Bhsj13's Avatar
how is your boost?
Old Jun 13, 2015 | 09:41 PM
griz's Avatar
Well I just checked and the system is only holding 7 psi. But again only leak I found was at the TB and its not even that bad. I'm lost, something is obviously leaking bad but I can't find it
Old Jun 14, 2015 | 07:55 AM
Bhsj13's Avatar
only holding 7 psi? hm.... check all vac line. what about the one to your wg actuator?
Old Jun 15, 2015 | 06:12 AM
griz's Avatar
Checked and its good
Old Jun 23, 2015 | 10:35 AM
Tamez10's Avatar
Evo 8 stock with ECU tuned at 0 percent duty cycle in the OEM boost control solenoid I had 12psi across the board, which I believe it's the lowest boost the WG can achieve. check your WG and turbo vaccum lines. I had no turbo pill as well.
Are you sure you didn't mess with vac lines?
Old Jun 23, 2015 | 10:52 AM
llDemonll's Avatar
boost leak test time. soapy water helps find things easily
Old Jun 23, 2015 | 11:43 AM
LetsGetThisDone's Avatar
Even with a boost leak, he should still hear the turbo sucking in air at WOT.
Still test for boost leaks, but also make sure the WGA and associated vac lines are in good shape..
Old Jun 24, 2015 | 04:07 AM
griz's Avatar
I have a leak at the throttle body seals and a very small one at one of my injectors, but I doubt that would be enough to bring me down to 7 psi. I'm going to check to make sure all my vac lines are good later but I don't know what else it could be.
And yes I do hear the turbo sucking air faintly but don't hear the stock dv releasing any pressure
dairyman
17
May 20, 2009 11:29 AM
dairyman
Apr 25, 2009 10:47 AM
CrackerJackToy
Jul 12, 2007 04:31 PM
inslowoutfast
May 12, 2007 03:35 PM
evodave
Jan 3, 2005 05:40 PM
