Crank trigger plate backwards?
Old Sep 12, 2017 | 02:49 PM
4b11slayer's Avatar
The reluctor wheel will be over the sensor instesd of in between it. Its pretty obvious.
Old Sep 12, 2017 | 04:52 PM
c4s3ys's Avatar
I have an extra i can throw in tonight. I'll keep ya updated. Thank you.
Old Sep 13, 2017 | 05:36 AM
c4s3ys's Avatar
Found the problem. Not calling anyone out here i still buy a ton of parts from them and will continue. But the STM fuel pressure kit comes with a small vacuum hose. When hitting boost it would cause that vacuum line to suck itself together stopping the vacuum of fuel. Making me go lean and have fuel cut.
Old Sep 13, 2017 | 07:13 AM
Biggiesacks's Avatar
congrats, thats great news. You should give STM a heads up about your problem. Im sure they will want to hear about it so they can take it up with their suppliers and improve Quality control.
Old Sep 13, 2017 | 11:17 PM
RightSaid fred's Avatar
There's no vacuum when you're on boost.
Old Sep 14, 2017 | 03:11 PM
LetsGetThisDone's Avatar
Lolwut? Sounds like the line had a cut in it, it certainly wouldn't get "sucked together" by boost, which is pressure.
Old Sep 18, 2017 | 07:28 PM
WhiteHat's Avatar
No, car will not run or drive if it's backwards. They usually don't run or drive if the cam one is backwards.
Just for reference, my car ran with it backwards, idled normal, driving felt like it was being limited by something.
Not sure how it did not hit or anything but flipped it back over and ran without problem.
Old Dec 5, 2018 | 11:58 PM
AndrewEvo4's Avatar
So I’ve just rebuilt my engine have spark and fuel but it won’t start, have tried to scan the computer but my scanner can’t connect to it, it’s a Evo 4 engine and ecu, is it possible that the crank angle plate is on wrong ? The engine turns over fine but doesn’t want to fire at all cheers
Old Dec 6, 2018 | 03:28 PM
Ev0ikon's Avatar
You got fuel and sparks. How are the compressions ?
Old Dec 6, 2018 | 05:14 PM
kaj's Avatar
kaj
If your scanner should communicate with the ECU and isn't, I'd start there.
Old Dec 7, 2018 | 12:46 AM
AndrewEvo4's Avatar
Hi so today had a auto sparky look at it and scanned it which showed a fault with the Maf sensor and that was it again checked spark timing and even made sure we had tdc perfect and still no luck it’s back firing out the intake tho
Old Dec 7, 2018 | 07:43 AM
kaj's Avatar
kaj
"tho"?
Old Dec 7, 2018 | 11:17 AM
IzzyRS's Avatar
Originally Posted by kaj
"tho"?
though
Old Dec 7, 2018 | 11:41 AM
Ev0ikon's Avatar
Do basic things first. Can you or your sparky confirm compression numbers across the cylinders?
Old Dec 7, 2018 | 11:45 AM
Ev0ikon's Avatar
which cam gears are you using?
