Rear main seal leaking
Old Aug 25, 2015 | 01:03 PM
Jptanada's Avatar
So I got quoted $680 to do the rear main seal job. I was wondering what other maintenance/mods I can do since the tranny is coming out? I already have the clutch and flywheel replaced. Bummed I'm taking a $680 hit for this but I might as well take care of other things. Thanks guys
Old Aug 25, 2015 | 01:26 PM
LetsGetThisDone's Avatar
Make sure to use an OEM throwout bearing. SInce you have to bleed the clutch anyways, get a stainless braided clutch line to go from the master to the slave cylinder. You could do a polyurethane front motor (roll stopper) mount, and replace the shifter linkage bushings at the trans with delrin or aluminums that are available from several shops.
That's a pretty good list I think short of getting the trans gone through...lol
Old Aug 25, 2015 | 02:04 PM
Jptanada's Avatar
Thanks man, I thought of even getting the tranny rebuilt by jacks. I'm still trying to get all my eggs in the basket before I pull the trigger on what I want to get done. Thanks for your suggestions.
Old Aug 25, 2015 | 02:09 PM
Unless you're going for big power, you just need the standard rebuild, with maybe the Evo 9 1st and 5th gear. Keep the stock final drive unless you're building a stroker motor with a decent sized turbo that will make a lot of torque (500+)..
06redrocket
Aug 28, 2011 03:06 AM
Rob_GPT
Nov 8, 2008 09:11 PM
93civEJ1
Nov 2, 2005 06:08 AM
fromgsx2evo8
Oct 28, 2005 09:07 AM
