Is it possible to install your own stroker kit?
Old Oct 1, 2015 | 07:03 PM
Jonno99's Avatar
Just been looking for a project and saw this:
http://www.prospeedracing.com.au/pro...9-i-beams.html
In theory would it be possible to DIY install this kit?
Old Oct 1, 2015 | 07:10 PM
LetsGetThisDone's Avatar
Its just an engine build. So, yes if you have the right tools...
Old Oct 1, 2015 | 09:11 PM
Jonno99's Avatar
mmmm...so if the bores and head were still in good shape, you wouldnt really need any machining done. you could also install a set of cams and also install your own beehive springs, still without any machining, leave the evo 9 turbo in place, perform your own tune and take advantage of all those extra torqs
all without taking it to a shop?
Old Oct 1, 2015 | 10:49 PM
If you have the tools to measure the cylinder bores, piston clearance, a hone, bearing clearance, etc, yes.
Generally, I have a machine shop do my honing and set piston to wall to what I ask for. I check everything else myself. If the motor is coming apart, you should get the head refreshed (valve job, new seals, etc), and that would require a machine shop.
doncarbone
E85 / Ethanol
17
Feb 12, 2015 04:42 PM
Evolution4g63
Jun 16, 2005 05:55 PM
evodave
Mar 9, 2004 07:25 AM
