Do FP JB SS turbos leak?
Old Nov 6, 2015 | 08:02 AM
KJS's Avatar
KJS
Particularly the Black. I've seen some threads about the SOME BB turbos having oil leaking issues, and was wondering if SOME JB turbos have the issues as well?
Old Nov 6, 2015 | 02:25 PM
evo8426's Avatar
Yes, but with proper crankcase ventilation it will not.
Old Nov 6, 2015 | 04:25 PM
Erik@MIL.SPEC's Avatar
And the newer Xona turbos should be even less prone, if I understand things correctly.
Old Nov 6, 2015 | 04:36 PM
KJS's Avatar
KJS
Can I use a twinscroll.manifold with the ss housing
Old Nov 6, 2015 | 04:48 PM
kikiturbo's Avatar
if you are talking about the new stainless FP housing then yes.. the flange is the same..
LetsGetThisDone's Avatar
yes
Old May 12, 2017 | 06:07 AM
bostonhatcher's Avatar
My JB FP black with SS housing leaks. I've always run 20W-50 VR1 gray bottle. I have the FP oil line with their .125" restrictor. I run my pcv just like factory except I added a Boomba PCV between the stock pcv and intake manifold to hold higher pressure. There is always a blotch of oil between the exhaust housing and center section on the bottom side. I can smell oil all the time while driving. I got pulled over by a police officer because it was smoking so bad out the exhaust cruising down a hill. This turbo has pretty much leaked from the get go. My factory 16g never did anything like this and I ran all sorts of pcv setups and oils and even ran it without a wastegate for a couple of years spinning it off the map.
I'm thinking about having it rebuilt but if it does it new then what's the point?
Old May 12, 2017 | 06:47 AM
You need to improve crankcase ventilation.
Old May 12, 2017 | 02:26 PM
KentStateTsi's Avatar
Veteran: Army
I had an issue with some oil around the compressor cover when I was running a 2 port with both lines to the valve cover. Now I have a 3 port and no more oil coming out. A pre turbo suction line really should be ran on most catch cans.
Speed Element
58
Apr 18, 2006 05:36 PM
Blacksheepdj
Lancer Troubleshooting
Mar 31, 2005 08:44 AM
