Bought used gt35r bad seals?
Old Nov 7, 2015 | 04:24 PM
sssr20det510's Avatar
I bought a used gt35r from a kid who had it on a sti and changed his up pipe and a few other things and changed the oil feed line to one without an oil restrictor not knowing it needed one and drove it around the block and noticed blue smoke so took it into a shop that told him the seals where blown. So he put on a 30r and and has just had this one sitting around for a while. So from what I've read the turbo should be fine just clean it up and use a restrictor. There is no shaft play and spins freely. Everything I've read you cannot rebuild this turbo what do you guys think. I was going to send it to FP and have it upgraded to hta3582r
Old Nov 7, 2015 | 04:52 PM
240Z TwinTurbo's Avatar
they don't "blow" so run it and report back
Old Nov 8, 2015 | 09:02 AM
Ya looks like I'll ship it to fp
Old Nov 8, 2015 | 09:59 AM
LetsGetThisDone's Avatar
Just run it. I'm sure there is nothing wrong with it. Turbos don't have seals, they basically have "gas" rings (like piston rings), they mostly rely on differential pressure to keep the oil in the CHRA. They don't just "blow". I'm almost certain if you install it with the proper oil restrictor it will be fine..
Old Nov 8, 2015 | 10:49 AM
Ya everything I have been reading it sound fine and got it for 200 bucks so can't beat that.
Bmurray
190
Sep 20, 2017 06:01 PM
Ferraritech
24
Apr 4, 2014 12:03 PM
jaxjoker
Northwest Region
Jul 17, 2003 12:55 PM
