Engine lag
Old Dec 25, 2015 | 04:38 PM
Adam Keith Lang's Avatar
Engine lag
I have a 03 evo 8 and out of nowhere my car will make boost to 20lbs like it was before (normal) and engine won't get up and go just barely accelerates at all very slow to none pick up need help replaced the fuel pump and still have the same issue.
Old Dec 26, 2015 | 12:55 PM
phillybuilt's Avatar
It's kind of a far fetch considering the small amount of details we have on the issue, but a local DSM guy had a very similar issue as you did, when his flex pipe collapsed. Try disconnecting the downpipe and see if you still have the issue.
Old Apr 21, 2016 | 10:27 AM
80203's Avatar
Sounds like you might have a boost leak I would check all the lines
Old Apr 21, 2016 | 12:12 PM
LetsGetThisDone's Avatar
If he had a boost leak like that, the car wouldn't hit 20psi...lol
Checked to make sure the cat didn't collapse or clog.
Old Apr 21, 2016 | 12:20 PM
80203's Avatar
You can still hit full boost and have a leak.
Old Apr 22, 2016 | 01:06 PM
Erik@MIL.SPEC's Avatar
Could also be OEM rubber intake and/or IC hoses collapsing too.
Adam Keith Lang
Jan 13, 2016 04:18 AM
LBLancerDude
Site Feedback / Suggestions
10
Mar 13, 2003 01:52 PM
AtO-MiX
Lancer Troubleshooting
12
Oct 11, 2002 11:12 AM
