Aftermarket oil drain plug washers?
Old Dec 31, 2015 | 04:01 PM
D2003's Avatar
Need to change my engine oil, the only Mitsu dealer in the area wants $3.5 for EACH oil drain plug sealing washer. Can anyone suggest a good aftermarket source (lots of Oreilly's in the area), or tell me the inside diameter of the washer, so I can have one ready when I remove the plug?
TIA
Old Dec 31, 2015 | 11:10 PM
LetsGetThisDone's Avatar
I want to say it's 12mm or 14mm.
Old Jan 3, 2016 | 09:11 PM
minus500's Avatar
If you go to the parts store, they should be able to look up the correct size for your car. I know Advance Auto will do that.
$3.50 is robbery for a little washer but at the same time, you're only changing the oil several times a year so it doesn't add up to much.
I would give you a tip which you may be well aware of, there is NO need to over tighten drain plugs. I see this ofter and then you end up with an oversized drain plug or worse, replacing the pan.
Old Jan 4, 2016 | 05:35 PM
ace33joe's Avatar
http://www.rockauto.com/catalog/more...nid=491&jpid=0
$0.81 each
Hyundai also used the same design for older cars, I got a bunch at $0.15 at local Hyundai parts dealers. (South Korea)
trinibt65
Evo X How Tos / Installations
Aug 19, 2015 11:12 PM
efinirx8
Nov 10, 2013 04:15 PM
Deraj
Jul 2, 2012 09:30 PM
SlowCar
Dec 30, 2005 04:07 PM
SlowCar
Dec 10, 2003 10:37 PM
