transmission gearing
Subscribe
Mar 8, 2016 | 09:36 AM
hi i am not familiar with the gearing ration on evo 9 transmission. I just got my transmission built and the shop had recommended evo 8 1st gear my stock 9 2-5 gear and 4.0 final drive for what i was looking to do with the car. i daily the car in the street and also drag strip. wanted to get decent mpg also. i know people recommend 9 1st gear and 4.11 fd. just want some thoughts if this was a good choice. the reason this shop told me to use the 8 1st was with the 4.0 the gear would be too tall.
Reply 0
Mar 8, 2016 | 10:12 AM
With a taller final drive than stock, the 8 first gear is what you want.
Reply 1
Mar 8, 2016 | 12:27 PM
why do you need a taller final drive? if your going to be drag racing or top speed runs, then go for it.
as i thought i was going to drag race my car a lot more than i did, hence the reason to use a 4.11 & only use 1-4th in the quarter.
I live in a hilly area & DD my car. once i went to a 4.11 fd with evo9 1/2 gears, = a nightmare. oem fd & evo8 1/2 = no problem.
im 50 years old & have been driving hi perf manual trans vehicles my whole life, this was absolutely the biggest gearing mistake i ever made.
I went back to evo 8 1/2 & oem FD.
if you live in the flat lands & need such a tall FD, then by all means go for it, as you need it.
simply dont do it to "just do it".
GL
Reply 0
Mar 8, 2016 | 02:11 PM
i'm over in Boston and its mostly flat lands over here. i like a taller fd just to keep the rpm lower when i do long trips. i figure it would give me better mpg. i guess i will see how it goes when the motors finished and everything together. thanks guys ill keep you posted on how it turns out.
Quote: why do you need a taller final drive? if your going to be drag racing or top speed runs, then go for it.
GL
Reply 0
Subscribe
