boost leak test question
Old Mar 19, 2016 | 06:33 PM
Cbr1000love's Avatar
hey i did a boost leak on my car and i found a found a few leaks.
- J pipe was leaking but i had a new gasket with my evo 9 turbo swap kit(waiting untill i get the 10.5 hotside)
-first cupler off intake manifold coudnt hold up
--both fixed
-throttle body shaft is pissing air like theres no tomorrow
-and the last is what would normally be the idle air screw(in other cars).. is it the same on a evo? and i guess there is a gasket in it?
happens to be the red # in the pic .. and im guessing the second(lower) red item is the gasket?
Old Mar 20, 2016 | 12:02 AM
LetsGetThisDone's Avatar
Yes, there is on o-ring on the idle screw. And you can get upgraded tb shaft seal from mil.spec or STM. They're both vendors on here.
Old Mar 20, 2016 | 07:38 AM
i ordered the mil spec seal last night so i still need a Tb gasket and the idle screw gasket. thanks for the response ill order it today.
Old May 16, 2016 | 01:12 PM
80203's Avatar
That seal from the factory seems to be a common issue mine was leaking there too once the new one went in no issues
aspensvt16
Aug 10, 2008 04:35 PM
elphalba
Mar 15, 2008 11:34 AM
dudical26
26
Jul 25, 2007 02:25 PM
MitsuJoe
Nov 19, 2006 04:21 PM
