2.4 rpm question
Old Mar 24, 2016 | 04:48 PM
STIbyebye's Avatar
2.4 rpm question
I'm upgrading to gsc r2's and kiggly beehives and the r2's are supposed to build power to 8500, but I've been getting mixed opinions on what I should rev to. My turbo is a custom apexi it's equilivant to a 3586r with a 1.06ar hotside. Some say 8k others say 8.5k is fine. Whats your guys opinions thanks again as always!
Old Mar 24, 2016 | 07:19 PM
LetsGetThisDone's Avatar
8k on the 100mm crank.
Old Mar 26, 2016 | 04:18 PM
Teal2nnr's Avatar
What the R/S ratio on the 2.4's again? isn't it like 1.56 or something like that?
Old Mar 28, 2016 | 07:29 PM
AreSTG's Avatar
Is this a rev limit you are going to bang on the street regularly or just at the track? I go over 9k at the track, but drive like a grandpa in the street
Old Mar 28, 2016 | 07:34 PM
STIbyebye's Avatar
Yea it's a summer car, so it will see a good bit of street usage something to do some damage to the local v8s lol
Old Mar 28, 2016 | 10:21 PM
roni4g63's Avatar
yeah 8k is a good number, even 8.5k but ideally 8k
Old Mar 29, 2016 | 06:54 AM
STIbyebye's Avatar
I guess alot will be dependent on where my turbo starts to fall off no sense spinning it if it is falling out of range. For street use anyways
Old Mar 29, 2016 | 07:55 AM
No, it's really more along the lines of piston speed is high on a 100mm crank, and they make a lot of extra harmonics. Regularly revving it past 8k isn't ideal for longevity. Sure, some guys do it at the strip in their drag cars, but that's not nearly the same as holding 3rd to 9k in between every corner of a twisty road, or at an autocross. Or even more punishing, at a track day.
Old Mar 29, 2016 | 08:11 AM
STIbyebye's Avatar
I'll probably stick to 8k then it's going to be a. Summer street car with some strip time here and there.
Old Mar 29, 2016 | 08:42 AM
bboypuertoroc's Avatar
Veteran: Army
This is great advice.
Even with a long rod 2.4L you don't want to constantly explore the outer limits of it's rev range.
Randal
Nov 27, 2012 06:22 AM
211Ratsbud
Nov 11, 2012 01:22 PM
SzuChenEvo
Apr 1, 2003 02:40 PM
