Driving without ACD Pump installed for a few days
Old Mar 24, 2016 | 09:17 PM
CeliOnce's Avatar
Rebuilding my ACD pump that has not been working and the solenoid broke which means I had to order another one and it'll be a few days before I can reinstall it.
Should I be fine driving without the pump, ie with the fluid line disconnected just for a few days, not doing anything radical with the car? I've been driving for a while without it working, which I understand is fine, but I want to make sure it's okay without the pump itself for a brief period of time.
I suppose it's just pneumatic fluid going to an actuator for the clutch pack, not lubricating the clutches or anything itself, so I feel like it should be fine but I want to double check.
Old Mar 24, 2016 | 11:58 PM
kikiturbo's Avatar
you can drive it as you want it for as long as you want it.. it is perfectly ok..
Old Mar 25, 2016 | 10:07 AM
drive955i's Avatar
Agreed. All the ACD pump does is activate the lock up of the transfer case to provide power to the rear. It hasn't been doing that for a while, it sounds. The gear set is still bathed in differential fluid. Just be sure to properly bleed the system when you reinstall the pump, so it can work effectively once more. You'll just have an extra fault code or two stored.
Old Aug 14, 2016 | 07:47 AM
wreckleford's Avatar
With the ACD not functional does the centre diff just work as an open diff?
Old Aug 14, 2016 | 09:29 AM
LetsGetThisDone's Avatar
Yea, and the car handles like **** lol. It won't hurt anything though. But I definitely would advise you to just cruise around and take it easy.
Old Aug 14, 2016 | 09:34 AM
Ok, thanks. Next question: What's cheaper, replace the busted AYC pump or buy a used non-ACD transfer?
Old Aug 14, 2016 | 12:27 PM
Idk, haven't had to consider that. I do know I would elect to fix the ACD. I've driven non-acd evo's, and the handling characteristics aren't as good.
Old Aug 14, 2016 | 03:33 PM
kikiturbo's Avatar
fix the pump
Old Aug 15, 2016 | 06:35 AM
[TK]'s Avatar
yea fix the pump if you can... I broke my solenoid and my pump been sitting on my tool box 2 weeks now... cheapest solenoid I can find at all is $200.... I just hate to replace the solenoid or even get a used pump for it to just go out again some day ....
Old Aug 15, 2016 | 07:52 AM
kikiturbo's Avatar
if you overhaul the pump an put it togeather with enough grease it will last a looong time..
Old Aug 15, 2016 | 10:18 AM
The problem is my solenoid is physically broken off of the pump (don't ask).
JB Weld, rebuild and pray?
Old Aug 16, 2016 | 11:07 AM
heel2toe's Avatar
^I don't see that working but you could always give it a shot...looks like they have a solenoid if you cant find one http://www.acd-pump.com/#!product/pr...-reconditioned
I also bet there are many members on here who purchased a new pump and have their old one sitting on a shelf wit a working solenoid. Maybe try a WTB and cross your fingers or reach out to that company fork over the dough and call it a day.
Old Aug 16, 2016 | 12:24 PM
[TK]'s Avatar
yea I put up a WTB thread myself a week ago with no hits. $200 for just that solenoid seems kinda high but no choice since I cant find it anywhere else
Old Aug 16, 2016 | 12:31 PM
heel2toe's Avatar
Supply and demand my friend...maybe try calling them and see if they will play ball? Other than that you dont have many options unfortunately.
I wonder what happens to the pumps the Mitsu replaces when one fails? Maybe try calling a couple local dealerships and see if they have a busted pump chilling there?
Old Aug 16, 2016 | 01:10 PM
kikiturbo's Avatar
FYI, evo X pump will have 2 solenoids that you can use.. just have to experiment a bit with the way they are oriented in the body... I did an e8 with evo X solenoid..
