CEL on after turboback?
Old Mar 27, 2004 | 04:38 PM
expl0d's Avatar
Well the CEL is on. I put the turbo back on 2 days ago. I went to autozone to pull the code, I forget what it was specifically but it was something: Catalyst amount changed? something of that nature.
Upon installing the turbo back, the gaskets broke, B&B is replacing them. But can the broken gaskets (aka exhuast leak) cause the CEL to pop on? or is this a common, expected thing?
Any help appreciated.
Old Mar 27, 2004 | 04:49 PM
1QWKEVO's Avatar
when the gaskets are changed, try resetting the ecu before startup again... Its just a thought but these cars run so dirty rich, adding an exhaust might changed the air flow enough to change the readings.
Old Mar 27, 2004 | 05:03 PM
MrBonus's Avatar
Your rear O2 sensor is reading more air flow and thinking that your cat is damaged. It's a soft code and won't affect performance.
Old Mar 27, 2004 | 05:17 PM
Brewski's Avatar
since september ive been driving with a cel light on since i got my turboback from ultimate racing.....never really had to worry about it...i help out at a garage and my boss lets me hook up the ecu every now and then to make sure theres nothing else tripping the cel besides that sensor.
Old Mar 27, 2004 | 05:33 PM
en1gma19's Avatar
^^ Ultimate racing test pipe/hi-flow cat aren't supposed to trigger a CEL. I have a UR test pipe and no CEL. had it for 7500miles. BTW....Mr Bonus is correct. 2 Os sensor is getting an invalid reading. Get a different test pipe. UR and buschur are guaranteed not to throw a CEL.
Old Mar 27, 2004 | 05:41 PM
Brewski's Avatar
ultimate racing also garunteed no cel like you said so i dont understand why but im afraid to waste my money on a knew test pipe if the light wont go off...know what i mean?
Old Mar 27, 2004 | 06:38 PM
Shahul X's Avatar
im using the UR turbo back... no cats, NO CEL
-shahul
moparfan
Jan 30, 2016 04:57 PM
rjsdxm
Jan 27, 2015 07:57 PM
analogEvo
Mar 3, 2012 08:58 PM
bsvaton
Oct 13, 2010 09:51 PM
