No CEL ?
Old Mar 2, 2012 | 09:36 AM
analogEvo's Avatar
No CEL ?
When I bought my car their was no CEL .it had a o2 sensor code.I fixed that but I still have no CEL so even when I get codes it won't come on?I swapped a working bulb into the CEL space and it still didn't work.
I then swapped it back to the open door or where ever I took it from and it worked again.
I didn't notice any random wires cut ,or sPliced .
Is there a dedicated fuse or something that I missing?
Old Mar 2, 2012 | 09:37 AM
BooHAHA's Avatar
is it disabled in the ecu?
Old Mar 2, 2012 | 10:21 AM
analogEvo's Avatar
How would I cHeck That? Use ecu flash?
Old Mar 2, 2012 | 10:39 AM
BooHAHA's Avatar
yeah you would need to use ecuflash and a tactrix cable to pull your map
Old Mar 2, 2012 | 10:56 AM
Tubzzz14's Avatar
same happened to me i had to go to my tuner turn my 02 sensor heater back on then reinstall my cat so it would pass........awkward this is for 9's
Old Mar 3, 2012 | 04:37 PM
analogEvo's Avatar
Hmm well I will plug it in and see what the deal is . Thanks for the input
Old Mar 3, 2012 | 08:36 PM
Integra9807's Avatar
Bump........…
Old Mar 3, 2012 | 08:58 PM
nytalonTSi's Avatar
So it doesn't appear for several seconds when you first turn the key on?
I don't recall being able to disable the CEL from coming on at all. Unless you have an AEM ems?
Mweisel
Feb 23, 2018 02:08 PM
EVOEvolved
Jul 3, 2016 03:30 PM
ruarctb
Lancer Troubleshooting
11
Apr 12, 2016 10:59 AM
Temujin
Jun 13, 2012 05:16 PM
newbienco
Jun 27, 2010 09:31 AM
