Evo8 ( weird probelm) hlep ...
Old May 8, 2016 | 11:01 AM
EVO(boss)'s Avatar
Hi ,
The car is running with normal and few parts whichs EF4 , 274 cams , HKS IC and piping , fuel pump , QM clucth and exhaust , 1100cc Id .. Nothing much .. The car tuned by TOM made 540whp on c16 on 30-31psi on MAF . The car was running HKS IC but the IC went kboom . I changed to VR IC now , i put the old c16 map but the car is running lean 12.8 , 13.2 afr i did 2 pulls ... Then i turned the car off and put the pump gas map then the car is not woring any more . After 2 days i restart the car and it runs but the car was super lean at the idle over 18 afr . Then i put the Omni 4 par sensor and AEM IAT and talked to TOM he sent me SD map and i start up the car and the car runs . But there is some weird act you guys can see/hear it in the VID
There is a weird sound like cutting fuel or miss firing on the idle ..
Old May 9, 2016 | 02:14 AM
EVO(boss)'s Avatar
Do u guys think thats bad Fuel injectors ?
Old May 9, 2016 | 07:39 PM
LCS's Avatar
LCS
I would check the plugs. Something is not right with coils or injectors.
Old May 9, 2016 | 09:00 PM
EVO(boss)'s Avatar
Just changed new plugs , sent the ID injectors to Bosch and they tested it and clean it and there was no problem at all . Still the problem is there ... How do i know if the o2 sensor is dead or work ? From evoscan but how to know
Old May 9, 2016 | 11:15 PM
05EV08's Avatar
1. Don't rev your car like that when you have an issue like this.
2. Listen to what people are saying. One of your cylinders aren't firing.
Old May 10, 2016 | 12:03 AM
EVO(boss)'s Avatar
Will check the coils today .
Thanks guys
Old May 10, 2016 | 09:45 AM
EVO(boss)'s Avatar
checked the coils and every thing and did compression test and all good the problem is there still
Old May 10, 2016 | 06:54 PM
LCS's Avatar
LCS
Where all the plugs ok? At least one of them should have signs of misfire.
Old May 10, 2016 | 08:33 PM
EVO(boss)'s Avatar
All good bro nothing wrong with them .. Do u guys think its o2 sensor ???
Old May 10, 2016 | 09:19 PM
EVO(boss)'s Avatar
I checked the new plugs as i changed it 2 days ago and started uo the car twice , all plugs are black .. The car is running extremely rich 10.8-11.2 on idle
Old May 10, 2016 | 11:34 PM
Evo9_Dubai's Avatar
Your o2 sensor is dead. That is why the car is running rich in closed loop.
Your misfire issue is related to ignition coils/plugs. Try a different set of coils to eliminate the problem.
I had a friend who's car would constantly misfire in high rpm, and he was convinced it wasn't his coils and that they were practically new, until he tried a different set off another car and it resolved his issue.
Old May 12, 2016 | 09:15 PM
EVO(boss)'s Avatar
Alternator problem. ... Thank you all
BoneEvo9
Jan 28, 2014 11:07 AM
NOMIEZVR4
16
Jul 2, 2010 07:24 AM
spooch
Apr 12, 2008 08:46 PM
yoderboy24
May 7, 2006 09:56 PM
Soon2BEVO
Feb 9, 2005 01:56 PM
