Rich tip in causing stall
Old May 13, 2016 | 02:49 PM
Evo9_Dubai's Avatar
Hello,
Quick rundown of setup:
Built 2.3L
FIC2150cc
PTE6466
Speed Density
Internal walbro 450, external Bosch 044
Here is a description of the problem:
The car was running fine without any issues what so ever, I swapped my in tank walbro 255, for a walbro 450. All is hardwired. I also have an external bosch 044.
After I installed the pump, did a few pulls and all was running well. I am running Speed Density. My car was tuned with a base fuel pressure of 58psi.
It ran very well throughout the winter season, now I start the car, try to drive it out, and as soon as I give it a little throttle and start depressing the clutch, it will go extremely rich and try to stall. If I give it more throttle, it will stay alive and buck hard because its too rich.
Please have a look at the log and you can see when the apply throttle while depressing the clutch, the car just dumps a lot of fuel and it stalls. Car revs just fine in neutral
Things I have tried:
Swapped the 4bar map sensor
Swapped plugs
COP Kit is new
Leaned out SD RPM from 500 to 2000rpm, no change
Lowered Base fuel pressure, no change
Tried pump gas, and E85. Both the same issue
What could cause this issue?
Updated; I may have found the issue. Checking if fixed.
Old May 14, 2016 | 11:29 PM
BiFfMaN's Avatar
Might need to adjust the Minimum IPW, and then set the Injector latencies to fit those injectors.
Should be a few threads on the subject.
https://www.evolutionm.net/forums/ec...nimum-ipw.html
your fuel flow is higher with the new pump, look at latencies and fuel trims
Old May 15, 2016 | 12:59 AM
Evo9_Dubai's Avatar
I thought the same, but the fuel pressure remained the same on the regulator after I adjusted.
Well I am thinking it is mechanical, since the problem got worse with time, to the point where the car is barely driveable.
I have come across a thread that somewhat described the issue I am having, so I will try to swap the coolant temp sensor and see what happens. I will update once it is resolved, in case anyone else faces a similar problem.
https://www.evolutionm.net/forums/ev...talling-4.html
I will also check if there is any gunk build up on the injectors, car has been running E85 for a while now.
Old May 15, 2016 | 07:28 AM
BiFfMaN's Avatar
Get the injectors cleaned and tested, should eliminate Dirty/bad injectors from the list of possible problems.
A bad coolant sensor should show up on you logs.
Old May 16, 2016 | 12:11 PM
Evo9_Dubai's Avatar
Sensor readings on the log seem normal. I will swap the sensor anyway to be on the sure side.
I took out the injectors, and there was no gunk.
Old May 17, 2016 | 10:13 AM
BiFfMaN's Avatar
Check your ISCV tables if you can, it might be in there.
https://www.evolutionm.net/forums/ec...ng-clutch.html
Old May 18, 2016 | 04:08 AM
Evo9_Dubai's Avatar
I changed the temp sensor, and it didn't make any difference.
I added the definition for Minimum IPW, and the value is at 0.784
The tables for desired ISCV are blank.
I am on 88591715
If i remove the clutch, the car will go forward, although if I slightly press the throttle, it will go rich and die, until I apply a lot of throttle. If I apply a lot of throttle, it will go forward, but it will start jerking really bad.
For some reason, I do not think the problem is a tune related issue, the only thing that has changed from the time where it was running fine and now, is the temperature. The car was tuned when it was 70F, now it is 105F
Fuel pressure was kept the same after the pump install, I tried to put pump gas and switching to my pump gas map, still the same issue. I can't seem to figure it out.
I will try stock coils tonight and rule out my COP kit being the issue.
Old May 18, 2016 | 11:19 AM
Evo9_Dubai's Avatar
I managed to get a good log when the issue is happening.
I also tried swapping my COP kit for stock coils, same issue.
Old May 19, 2016 | 01:18 PM
Evo9_Dubai's Avatar
My next step is to try to swap injectors for stock ones and see what that gives.
If someone has any suggestions, please let me know.
Old May 21, 2016 | 02:15 PM
Evo9_Dubai's Avatar
I was going through the logs, and noticed the timing is dipping to 5* where the car is attempting to stall. On my map, on that specific load & 500 rpm, timing is 11 degrees, although the car is going to 5* ... Is it normal or is my ECU going coucou
Old May 22, 2016 | 01:59 PM
Evo9_Dubai's Avatar
Tried to swap the ECU with a working one, and it still did the same thing.
I am completely lost here. If anyone has any suggestions, I would highly appreciate it.
Old May 24, 2016 | 08:05 AM
Evo9_Dubai's Avatar
I disconnected the ISCV and the problem went away.
Old May 24, 2016 | 01:13 PM
Klaiceps's Avatar
I swear that ISCV does some strange things when it fails.
Old May 24, 2016 | 01:42 PM
Evo9_Dubai's Avatar
It drove me nuts. No CEL at all.
I checked every single sensor, ecu, plugs, COP, knock sensor, timing marks, tensioner... I even thought it was crankwalk And I was about to drop the oil pan.
A friend of mine walked over and simply disconnected my ISCV, then he said go for a drive... And it left me speechless
drifterific
Jan 29, 2011 04:18 PM
EvolutinIX
Jun 13, 2010 12:32 PM
CrackerJackToy
30
Jun 18, 2007 03:10 PM
honda-guy
Sep 9, 2005 09:20 PM
