cam questions.
Old Jul 7, 2016 | 11:28 PM
cmiller10's Avatar
cam questions.
hello I have a few questions. I have a pretty stock evo 8. it has an exhaust, intake and for some odd reason a fuel pump. I have a set of 280 bc cams I want to put in. I was wondering if it would be fine to put them in with out any other big mods (turbo, port polish, ect.) I will get a tune and I will be putting in valve springs, hla, cam gears, head studs and headgasket all at the same time. I talked to a tuner here and he said it might make more hp it might not. so im looking for a second opinion or maybe some dyno sheets or something. I really just need to know if the car will run fine with out a bigger turbo. I have a bw s366 but I want to build the engine befor I put that in. and I need a t4 manifold for that.
Old Jul 8, 2016 | 05:27 AM
ronaldo9's Avatar
My advice is to have a goal in mind of what power you will make and what your power band will be like. You really want the cam to match the setup. Are you trying to rev really high and forgo the midrange? If the answer is yes then for sure continue with your build.
Old Jul 8, 2016 | 07:42 AM
egis's Avatar
Honestly don't expect a lot of power from these cams. I had them and I had the same bolt ons and stock 8 turbo like you. On 93 octane I made 310 hp at 23 psi on AMS dyno years ago.with same cams ,9 turbo on e85 made 365@31 psi on mustang dyno .
Old Jul 8, 2016 | 12:18 PM
Teal2nnr's Avatar
Those cams will not work well with a stock turbo. They're going to push the power band out of the efficiency range of the turbo.
Old Jul 8, 2016 | 12:22 PM
foxbat's Avatar
280 are meant for bigger turbos. I tried the exact same model on a 2.0L with Tomei Arms 7960 turbo. Low end power loss was so significant the car was no fun to drive anymore, we removed the 280s & replaced them with BC stage 1 cams which as I recall are 266.
Old Jul 8, 2016 | 01:23 PM
cmiller10's Avatar
U was told by the tuner to get an evo 9 exhaust side for the turbo and it'll make more power then with what I have now. I'm not looking to make a racecar just yet. I have that bw and when it gets put in I'm going to try to get it to rev out to 10 or 11k
Old Jul 8, 2016 | 07:04 PM
LetsGetThisDone's Avatar
What?
Old Jul 9, 2016 | 12:05 AM
Teal2nnr's Avatar
oh god....
Old Jul 9, 2016 | 03:39 AM
cmiller10's Avatar
I guess yall missed my jokes. what I really want to know is if it will end up hurting the car with the cams only or if it will be fine. I don't expect it to make significant gains im just wondering how the car will handle it.
Old Jul 9, 2016 | 08:01 AM
Bhsj13's Avatar
LOL get rid of them ad get kelfords or s2's.
Old Jul 9, 2016 | 03:11 PM
cmiller10's Avatar
What's the difference if you don't mind me asking? I know none of the cams are ever truly the same with the durations and lobe profiles but why a kelford over a bc?
Old Jul 9, 2016 | 08:35 PM
ronaldo9's Avatar
Better quality there are old threads showing a BC cam breaking. I haven't had personal experience with a BC cam for example but Kelford and GSC would be my favorite options. Have a read for the cam test that was done years ago and hopefully that helps you with your decision.
https://www.evolutionm.net/forums/ev...l-17-cams.html
Old Jul 10, 2016 | 09:04 AM
cmiller10's Avatar
in yalls opinion would it benefit me more to put the cams turbo and other build parts into a 2.4 build?
Old Jul 10, 2016 | 09:23 AM
Bhsj13's Avatar
an evo 8 needs cams to make good power imo.
uranium9v
Lancer Engine Tech
159
Aug 15, 2006 01:02 PM
Vivid Racing
Nov 4, 2003 10:22 AM
majestic lancer
Oct 13, 2003 07:02 PM
uranium9v
Lancer Engine Tech
18
Dec 12, 2002 04:57 PM
