Turbo Suggestions?
Old Aug 9, 2016 | 07:01 AM
Luke Cabrera's Avatar
Turbo Suggestions?
Hi guys, will be replacing my current car for an Evo 8 or 9 and I intend to make some modifications to it. Was wondering if you guys could recommend me a good turbo or turbo setup for around 400 to 500 hp and with as little turbo lag as possible. Thanks in advance.
Old Aug 9, 2016 | 08:13 AM
awhit17's Avatar
FP71HTA. Will get you to 500 crank hp on E85 and spools basically like a stock turbo
Old Aug 9, 2016 | 08:24 AM
LetsGetThisDone's Avatar
What fuel do you plan on using to make the power goal? As well as other supporting mods. There are a few different ways to get to that goal, it varies greatly on what fuel you'll be using. And the overall setup will determine responsive the car is vs just making peak power.
Old Aug 9, 2016 | 09:21 AM
nemsin's Avatar
What is your budget and how will the car primarily be used?
Old Aug 9, 2016 | 03:00 PM
Jonno99's Avatar
See Letsgetthisdone signature and do the same as him ^^
Old Aug 9, 2016 | 07:18 PM
I'll be using it for both street and track purposes. Plan to stick to standard Petrol for the build.
Old Aug 9, 2016 | 07:20 PM
The car will serve as a daily drive and a track car too. Budget isn't a concern, I just want to get a setup with minimal turbo lag.
Old Aug 9, 2016 | 08:16 PM
Also, what do you guys think of the following turbos?
+ FP GREEN 73HTZ
+ HKS 3037S
+ BorgWarner EFR 6258
+ BorgWarner EFR 6758
Old Aug 9, 2016 | 09:45 PM
All of hose turbos will barely, if at all, hit 400whp on pump gas.
Old Aug 9, 2016 | 10:09 PM
What do you recommend then?
Old Aug 10, 2016 | 04:23 AM
wickedep's Avatar
400-500hp on pump...fp black. nothing else is really going to come close to the upper scale of those figures. on pump gas.
Old Aug 10, 2016 | 07:25 AM
nemsin's Avatar
Fast spooling 400whp turbo options include:
- HKS7460R, probably the fastest spooling 400whp option, but a bit fragile for track use.
- FPGreen, if spool is the focus you will want the MHI housing, which they no longer offer. Maybe contact FP and see if they can source you an MHI housing and build you one.
- Blouch 1.0/2.0XTR, the 1.0 will spool faster, but require more boost to hit 400whp.
- Full-Race Motorsports EFR 7163 kit, if you don't mind spending $5K+ on a turbo kit, this one is the one to get.
All (pump gas) 500whp turbo options will be laggy on a 2.0 evo.
Old Aug 11, 2016 | 09:42 PM
Redline-Z's Avatar
Veteran: Air Force
71 HTA and 73 HTZ will surely do 400 on pump 93 with all supporting mods, they flow 51 and 54lbs respectively
Old Aug 13, 2016 | 11:45 AM
[TK]'s Avatar
71hta cant go wrong with that
Old Aug 14, 2016 | 11:37 PM
wickedep's Avatar
he wants 400-500whp guys...all great suggestions for 400whp'ish requirement. But if he needs to go higher..then turbo needs to get bigger too. unless you swap to E85. then even 71hta becomes a contender which will be damn fast spooling.
