Trans Swap: Evo X trans in Evo 8/9
Old Dec 27, 2016 | 05:03 PM
chadnick's Avatar
It appears that the evo x 5 speed transmission is superior to the evo8/9 transmissions. Has anyone ever swapped the Evo X trans onto a 4G63? Does anyone offer a kit for this?
Old Dec 27, 2016 | 06:03 PM
barneyb's Avatar
It appears - what's different?
Old Dec 27, 2016 | 06:11 PM
kaj's Avatar
kaj
The VIII/IX 5spd holds up to anything. Why would you need something better?
Old Dec 27, 2016 | 08:29 PM
LetsGetThisDone's Avatar
The synchros are a more modern design in the X. That being said, the X trans won't bolt up to the 4g63. The X trans, tcase and 4b11 does fit in the CT9a. Mitsu ran it in WRC for testing back in the day.
Old Dec 28, 2016 | 12:23 AM
kaj's Avatar
kaj
The whole thing? That would be interesting.
Old Dec 28, 2016 | 01:12 AM
kikiturbo's Avatar
not really... the only good thing about that engine is the double mivec.. the rest is a potential pile of problems and ecu is too complex for its own good..
Gearbox is not nicer to shift than the VIII/IX 5 spd.. and the ratios are nothing to write home about..
Also, X gearboxes had major central diff problems with pins wearing out prematurely..
Old Dec 28, 2016 | 01:28 AM
kaj's Avatar
kaj
so chadnick is off their rocker?
Old Dec 28, 2016 | 01:32 AM
kikiturbo's Avatar
I am just glad no one suggested a SST swap into a VII/IX..
Old Dec 28, 2016 | 07:01 AM
chadnick's Avatar
Thanks for the info.
Here's one review of the X trans with some comparisons to the VIII/IX trans: http://www.jackstransmissions.com/pages/evox-review
Old Dec 28, 2016 | 07:56 AM
Better cylinder head (once ported), double mivec, 4 bolt mains, lighter weight.
X gearboxes are definitely of a better design than the CT9a. They also no longer have the center diff pin issue. That was 08's and 2010's...
Old Dec 28, 2016 | 03:19 PM
kikiturbo's Avatar
if we are doing a list, lets not forget weak block, short rods, exhaust manifolds that crack every 30K miles and weak valves that need upgrading when going for better cams.. ...
contemplating a full engine swap because the gearbox has better 4th synchro and some linear bearings on shift rods is a bit much IMHO.. Still needs better gearing tho..
Old Dec 28, 2016 | 06:24 PM
RazorLab's Avatar
not really... and ecu is too complex for its own good..
Uhm... what?
Obviously a statement from somebody that doesn't actually tune them. If you think the ecu is too complex, A). I'm sorry it feels so complex to you. B.) Don't try tuning a modern MED ECU, they make it feel like the Mitsubishi ECU is a abacus.
Old Dec 29, 2016 | 03:25 AM
kikiturbo's Avatar
Originally Posted by razorlab
Uhm... what?
I actually do tune them from time to time and I agree with you.. I wasnt very clear.. my point was that it is very complex from a stanpoint of someone doing a complete engine swap.. after all, would you go to all that trouble just because of few minor improvements in the gearbox (and a whole lot of new problems with the X engine)
Old Dec 29, 2016 | 12:44 PM
I wouldn't do a X swap and keep the OEM ECU, I also just wouldn't do it. Both engines have their own issues. And it would be a lot of work for close to the same result. I simply said the X trans wont bolt up to 4g63, but the whole X engine/trans/tcase will fit in the CT9a. I wasn't saying to actually do the swap lol
Old Jan 3, 2017 | 01:56 PM
94AWDcoupe's Avatar
the X trans isnt worth the headache of any kinda swap work. the changes made to trans are nice tweaks. some of them can be added to the 8/9 trans during a rebuild. my opinion is the evo 8/9 trans is nothing short of amazing when it is paired with a nice clutch. the devil in the details is a good clutch makes any trans shift well. a lightweight disc is FAR more important to any mod you can do to the trans in an effort to make it shift good.
kpt6
12
Jun 2, 2015 07:18 PM
EVO8 WHOA
Nov 16, 2014 09:38 AM
evo854880
Sep 5, 2013 05:56 AM
jack syn
Dec 1, 2006 04:16 AM
