Downpipe thread
Old Mar 4, 2006 | 08:23 AM
  #196
David Buschur's Avatar
A 3" downpipe is a waste of time, shadow1? Wow, that's not true.
I'd highly recommend a full 3" turbo back, and we do sell 2.5" downpipes, but it you are going to do it do it once and get it over with.
As a side note, ANY mofication to the factory cat is illegal, so if you are going to modify it or remove it you have already broken the written law on cats.
Check out our website if you want the lightest highest flow exhaust on your EVO.
David Buschur
www.buschurracing.com
Old Mar 4, 2006 | 08:43 AM
  #197
wicked-won's Avatar
my hardest part is trying to get one that stays what i feel is an acceptable distance away from the oil pan and away the center diff on the 2005
Old Mar 4, 2006 | 10:43 AM
  #198
shadow1's Avatar
David Buschur
David, I never implied that a 3" DP is a waste of time. In fact, a full 3" setup is probably the best way to go. But for those of us running JDM exhausts, they all neck down at the cat flange. So, the way I see it, why go from a 3" DP only to neckdown to 2.5 or 2.75" (depending on the catback) at the cat flange? I suppose the best setup would be to cut off the neckdown and have a full 3" flange welded on.
Old Mar 4, 2006 | 10:48 AM
  #199
shadow1, from post #195 you said this:
"I would not go with a 3" DP - waste of time." I would say that you did say it is a waste of time
I would highly recommend cutting any restictor out of the exhaust and making it a full 3" or just trade it in and sell the old stuff.
David Buschur
Old Mar 4, 2006 | 11:09 AM
  #200
shadow1's Avatar
David Buschur
I would not pretend to know more than the legendary David Buschur. I was specifically answering another Evo owner's question that had an HKS catback. HKS has a big time neckdown at the cat flange (stock size, whick is 60mm). Hence my statement saying that a 3" DP would be a waste. Even my Tanabe catback is 72mm at the cat flange.
Old Mar 4, 2006 | 12:07 PM
  #201
7m6m4's Avatar
great thread
Old Mar 4, 2006 | 12:15 PM
  #202
7m6m4's Avatar
is their a good downpipe for an RS*R GT-2 Cat-Back?
Old Mar 7, 2006 | 01:45 PM
  #203
99subi's Avatar
what d/p will fit the evo 9? , i was told the 02 bung is on the wrong side on some of them
Old Mar 9, 2006 | 07:23 AM
  #204
Yes, it absolutely fits on the EVO9!
David Buschur
Old Mar 9, 2006 | 10:54 AM
  #205
DarkEvo's Avatar
What kind of gains would get if you got a down pipe and kept you stock exhaust? all i have is a dynoflash mail in flash and a k&n drop in. In other words, is it worth it?
Old Mar 11, 2006 | 08:06 AM
  #206
scb1999's Avatar
i'm installing an Espelir DP today. do i need to use heat wrap?
Old Mar 12, 2006 | 09:57 AM
  #207
SA_Evo's Avatar
Is spracing dp the same as a sp engineering dp? If not has anyone have some info on the spracing dp?? A guy on thus website is selling one for 80 bucks shipped. If it is a good deal then I would like to buy it since my (New) HKS Hi power is sitting in my room waiting for my (used) perrin dp to get here on wed
Old Mar 13, 2006 | 08:47 AM
  #208
Changing the downpipe and nothing else on the car will get you nothing.
David Buschur
Old Mar 16, 2006 | 08:11 PM
  #209
tougetuned's Avatar
was wondering if the BuchurRacing 3in SS DP flanged for non-BR cat-delete/hfc will bolt up to stock cat (temporarily), until i get a 3in test-pipe/hfc?
-or-
does the BR 3in SS DP w/cat delete come with a cel fix and will bolt up to non-BR 3in cat-back exhaust?
thanx
Old Apr 26, 2006 | 08:54 AM
  #210
alloyic_rs's Avatar
Anyone have anything against the LS 3 inch dp with flex? http://www.lancershop.com/customer/p...pa<br /> ge=1
Only bad thing bout the flex is that it would make some turbulence but in turn its better for the engine as it suppresses all of its movements. Feedback appreciated.
