Boost fluxiating
Old Jan 14, 2017 | 07:45 PM
Jon Mello's Avatar
Boost fluxiating
Hello I have a completely stock 05 RS I just bought the car a few months ago and I just recently noticed it was only pushing 1.0~1.1 bar and from what I've read it's supposed to be around 1.4 stock. I thought it was a boost leak until a few days ago it went down to .7 bar. The day after it went up to 1.3~1.4. It's been changing every day but it stays solid at one of those 3 until I shut the car off. From what I've read it looks like my boost control solenoid could be faulty. Or just a electrical problem in general. Lights flicker and my battery resets itself randomly. My middle light in the cluster just went out yesterday. Is there any way I can check if my solenoid is bad? I had my battery checked when I first got the car because of the lights flickering randomly.and the battery is good and alt is good.
Old Jan 14, 2017 | 08:13 PM
llDemonll's Avatar
is your ground cable good? this seems like an electrical issue with all the other problems you're describing, not a mechanical issue
Old Jan 14, 2017 | 08:38 PM
Jon Mello's Avatar
that's what I was thinking. I didn't know if it would mess with the boost like that.
Old Jan 15, 2017 | 12:40 AM
NotThisFool's Avatar
Have you checked out wiring under the dash? There could be a chance wires may be touching. Previous owner could have installed boost, wideband gauge. Or alarm system. Food for thought. I had a problem similar to this on my integra.
Old Jan 15, 2017 | 06:35 AM
Jon Mello's Avatar
This might be the problem too. If something is messing up the flow in the harness and the boost solenoid is only getting some juice would that be why it gives me different psi every time. I'll be checking wires and ground today to see if I can find out what's wrong.
Old Jan 15, 2017 | 03:12 PM
m_0ney_pit's Avatar
May want to check the ecu plugs to. Sometimes if there was a wire tapped into an ecu plug they let the wire dangle
Old Jan 15, 2017 | 05:35 PM
barneyb's Avatar
If the lights are flickering it could be the ECU is loosing power, shutting off and restarting. Settings in the engine computer may be getting erased.
Usually problems like this turn out to be simple, once found. Clean the battery connections and reconnect. Then start finding, cleaning and reassembling the ground connections.
Old Jan 15, 2017 | 05:43 PM
4b11slayer's Avatar
Have you inspected the solenoid and lines going to gate and boost source?
bwanner
Aug 31, 2012 05:38 PM
wingnut
Jan 20, 2005 11:11 AM
blue beast
Mar 29, 2004 02:52 PM
