Recirc on Speed Density Setup?
Old Feb 15, 2017 | 02:37 PM
V.8MR's Avatar
This is an interesting question and I'd like to have the options you mentioned when I convert to SD as well.
Sub'd
Old Feb 15, 2017 | 02:48 PM
4b11slayer's Avatar
Just buy a sd intake and have someone weld on some ports for the hoses.
Old Feb 15, 2017 | 03:19 PM
211Ratsbud's Avatar
The fp intake is what you seek. Silicone cuts very easy if needed. It is a direct fit and trimming the bov stub is not worth anyone complaining about- and I'm far from a fp nutswinger. 😂😂
Old Feb 15, 2017 | 04:54 PM
TrendSetter's Avatar
Only pro's, yes.
cons: no off the shelf availability
Old Feb 15, 2017 | 05:14 PM
LakerRaider's Avatar
lmao, right
Old Feb 15, 2017 | 05:22 PM
Honestly tempted to get the FP and just chop it up. The jm fab seems to have what i need, but im scared of fitment that i wont be able to chop up.
now the question is, do i put the Tial QR on the ghetto stock uicp or to get the ets short route UICP with recirc pipe. If almost sure from pics, that the recirc pipe on the UICP is on top of the UICP rather than under like the stock uicp? if i went ets, id also need no tial flange im guessing
Old Feb 15, 2017 | 09:07 PM
4b11slayer's Avatar
I have the fp intake and also short route uicp from vrspeed
Old Feb 15, 2017 | 09:26 PM
which bov?
Old Feb 15, 2017 | 09:31 PM
4b11slayer's Avatar
Crushed evo 9 bov
Old Feb 16, 2017 | 06:09 AM
schuhie's Avatar
Originally Posted by LakerRaider
I just find it odd that there are almost no options that have recirc port AND the nipple for venting to catch can, specifically for speed density. STM has an SD intake that is vented, but no recirc. Then they have maf intakes that obviously have recirc but not vented. It makles me wonder if there is really just no one out there running recirc bov , vented at the intake, on SD??
This is the only thing i found that may work
https://www.maperformance.com/collec...ant=8413344579
I run this exact setup. I run a radium can hooked to the intake with a synapse DV recirc'd into the intake on SD. My intake pipe is an older cast HKS one i believe that had a maf adapter on it. I pulled the maf adapter and bought a foam perrin filter that was the right size to slide right on the intake pipe.
Old Feb 16, 2017 | 07:37 AM
LetsGetThisDone's Avatar
Yes. God forbid you have to build a tube, with a another tube welded on to it. I'm sure if the OP called STM they could build one no problem.
Old Feb 16, 2017 | 06:05 PM
i make everything myself. this place is full of entertainment with how helpless most members are.
Old Feb 17, 2017 | 01:34 AM
Fab something up for me. I'll pay. I don't have the time or resources to do that. If not, I'll be calling STM to see what they can do
Old Feb 17, 2017 | 06:32 AM
211Ratsbud's Avatar
Why are you against the fp silicone intake?
Old Feb 17, 2017 | 07:01 AM
EVO196's Avatar
do you have pix?
