Help!!! Multiple issues
Old Mar 3, 2017 | 07:29 PM
  #61
nor11384's Avatar
FCOTM Winner
Originally Posted by Tommyfacekicker
Another
dude in the picture on post #44 i can see that the wiring for the cop is absolute ****...no wonder the misfire went away with stock coils...i bet you a milkshake thats your problem right there...
Old Mar 4, 2017 | 12:17 AM
  #62
Tommyfacekicker's Avatar
Originally Posted by kaj
Is that a stock throttle body???
It's the full blown 70mm throttle body.
Old Mar 4, 2017 | 12:24 AM
  #63
Update: so I put new plugs and coil boots = fixed the misfire problems. Fixed 99% of my boost leaks! and I added the new full blown throttle body. I just got retuned tonight and the car feels great. The only issue is that my aem boost gauge is reading 22 psi only. Pretty sure my gauge needs to be replaced now. But yea my car feels like it was suppose to feel 4 months ago. Smooth, hits hard, spools quickly, pulls hard and no knock
Old Mar 4, 2017 | 12:32 AM
  #64
Special thanks to Kevin Vang of KEVINTUNED out of fresno, ca. Got my ride running good Again.
Old Mar 4, 2017 | 12:52 AM
  #65
kaj's Avatar
kaj
Out of this whole l thread, you got one person to help. That's all it takes. Congrats.
Old Mar 12, 2017 | 10:18 AM
  #66
Update: I maxed out my rod on my wastegate actuator to the point where it can't get any shorter. I finally saw 29 psi after I did this. Idk how long the wastegate will last me or if till survive but at least I am finally seeing my target boost
So everything is basically fixed on my car now. Hopefully this info will help someone in the future.
Old Mar 12, 2017 | 10:54 AM
  #67
kaj's Avatar
kaj
Are you running a IX WGA on an VIII turbo? I ask because I seem to remember them being different lengths. And if it's a stock WGA, I'm really surprised you were able to reach 29psi. That's waaaaay more than the spring is set for LOL.
With that much preload, it can affect day-to-day, part-throttle driving, but as long as you are seeing desired peak boost, meh.
Old Mar 12, 2017 | 04:01 PM
  #68
Ill put a picture of how it looks. I'm using a ebay turbo. So far so good. I think my issue was just the boost leaks and the wg issue.
Old Mar 12, 2017 | 04:31 PM
  #69
4G63_EVO's Avatar
No need to defend your tuner. You trust him, that's what matters.
Can your turbo do 30+ psi?
Off the top of my head, inconsistent boost could be:
Turbo (New means nothing. Ask MAP Also, it's a no-name turbo that you may want to trash, anyway)
WGA
boost solenoid/boost controller
Tune
Maybe someone else could chime in.
Your not using spark plugs for an VIII, are you? They are a different size And tend to "blow out ".
unless you are shooting for 500+whp, I'd also go back to stock heat range ( not part of your problem, but no need to run a cold plug ).
Edit: Read through entire thread. God job getting it back running normal!
Old May 20, 2017 | 01:04 PM
  #70
I put on a 35r turbo kit and got retuned and the car is running a lot better. I didn't change anything else besides the turbo, licp, exhaust mani. Maybe the smaller turbo and high psi was affecting my low rpms. I think my problem may have also been weather too. But I'm not 100% sure on the weather part bec it didn't happen to any other guys that I know.
Old May 20, 2017 | 09:56 PM
  #71
kaj's Avatar
kaj
neither of those would make any sense.
SimpleAznMan
Lancer Troubleshooting
11
Jan 4, 2025 03:34 PM
adupree
Aug 15, 2015 07:45 PM
cficare68
May 13, 2012 08:43 AM
Benja
Dec 17, 2011 08:49 PM
PARTYHARDCARLOS
Lancer Engine Tech
15
Dec 23, 2007 02:03 PM
