RPM rises 400 when doing 3 to 4 shift [MERGE]
Old Jun 6, 2005 | 09:13 PM
  #181
Dropspeed's Avatar
My update,
I removed my Vishnu 3" standard exhuast,downpipe,cat and installed my stock downpipe, cat and a Thermal 3"
Problem gone................On my car I am going to have to say it was do to lack of backpressure from the higherflowing exhaust system and no tuning.
My .02 cents
Mattj
Old Jan 16, 2007 | 11:24 AM
  #182
CaliMR's Avatar
any fix yet?
any fix yet? i do not get the rpm rise, but it does hang and then drop slowly like a really heavy flywheel. it does it even if i rev it while not moving, so i do not think it is related to the clutch
also, when i turn off the ignition, it continues to run for a second before the engine stops. i assumed it was just because of the boost being used up and the extra fuel because they run rich, just a turbo thing. however now i am wondering, does everyone have this? could it be related to the hanging rpms?
thanks
Old Aug 21, 2008 | 09:05 AM
  #183
wesside's Avatar
I hate to bring back a really old thread but I accidently came across this and thought if anyone reads this and has an issue then just go here
https://www.evolutionm.net/forums/sh...=throttle+hang
I fixed mine end of last year it's just on the 05 & 06 evo's
Old Nov 5, 2008 | 07:02 PM
  #184
Oettinger's Avatar
Any solution for this problem??
Old Nov 6, 2008 | 04:57 PM
  #185
Oettinger's Avatar
up!
Old Nov 7, 2008 | 12:25 PM
  #186
Oettinger's Avatar
help!!! for the problem!!
Old Nov 7, 2008 | 01:42 PM
  #187
tweakdsm's Avatar
check your Throttle body inside, there migt be some gunk inside, clean it with tB cleaner, just dont spray it inside This might fix the problem. Also when was the last time you changed your trans oil?
Old Nov 7, 2008 | 05:05 PM
  #188
Oettinger's Avatar
Is important trans oil for my problem of idle drops to 400rom?
Old Nov 21, 2008 | 06:06 AM
  #189
Oettinger's Avatar
Where is the solution... clutch+ throw?? change to aem?? I read all pages, very confused...
I change, Step valve idle, change maf, change air-filter, etc... No solution for my.
Old Nov 23, 2008 | 03:15 PM
  #190
Dr. SS's Avatar
started to experience this recenty? what is the cause ?
i have an 03 and it never did this until recently....
any ideas?
Old Oct 4, 2013 | 11:32 AM
  #191
mc14's Avatar
Same problem... get a tune it's excess fuel in the map 95% sure.
Femi
AEM EMS
23
Apr 5, 2016 11:38 AM
neonglh
Apr 16, 2015 06:18 AM
scheides
Mar 1, 2014 09:45 AM
Evorange
Feb 11, 2013 04:33 AM
STi2EvoX
57
Sep 18, 2010 09:40 AM
