Car bogging/jerking on boost
Old Jul 31, 2017 | 06:24 AM
4G63_Crazy's Avatar
5 Year Member
Hey everybody,
i bought my car (05 evo Mr) around 4 Months ago and everything I went on boost, it would always pull hard. However, in the last month or so, my car has been acting up.. When I would get on boost, sometimes, the car would stutter, but now after driving it today, everytime I get in boost or past 4000rpm the car starts jerking and bogging down.. I'm not sure why this is happening and it concerns me as this is my daily. Any help would be appreciated! Thanks for the help!
Old Jul 31, 2017 | 07:51 AM
4G63_Crazy's Avatar
5 Year Member
Also, when I am on the highway on 6th gear, the car like "hiccups". It loses power for like.5 second then jumps back into power
Old Jul 31, 2017 | 12:40 PM
4b11slayer's Avatar
Inspect plugs would be my first step.
Old Aug 1, 2017 | 05:04 AM
TariqEvo's Avatar
and then coils
and then test for a boost leak
Old Aug 3, 2017 | 08:02 AM
4G63_Crazy's Avatar
5 Year Member
So I finally got the chance to pull the spark plugs out and here they are. They look worn, but still not sure if this was causing the problems.. What do to you guys think?
Old Aug 3, 2017 | 10:53 PM
RightSaid fred's Avatar
Need a better photo from a different angle.
To me it looks like 3 of them have the threads wet with oil but it might be just the angle?
Plugs themselves don't really cause problems, they're just an indicator of what else is broken.
Cause and effect.
Oil on the threads usually means broken ring lands because it's been knocking with too much boost.
But you don't want to know that.
Old Aug 4, 2017 | 01:47 AM
slocho's Avatar
I run copper plugs but even then i was having issues like you are describing. Mainly at WOT and full boost my car would sputter. I swapped plugs and nothing changed.. so i swapped coil wires with new OEM wires and havent had an issue since.
​​​​​​​that was around 90k miles and im mostly stock 05 evo 8, hope that helps
Old Aug 4, 2017 | 10:21 AM
4G63_Crazy's Avatar
5 Year Member
Cause and effect.
Here are some better pics..
The thing is that there was no blue smoke or any smoke indicating worn piston rings.
Old Aug 4, 2017 | 10:23 AM
4G63_Crazy's Avatar
5 Year Member
​​​​​​​ Thanks dude, if nothing else works, I'll be sure.to check the coil wires!
Old Aug 4, 2017 | 10:35 PM
4b11slayer's Avatar
Plugs look fine. I run coppers bpr8es they are 2.49 each. Cant go wrong.
Have you swapped your map sensor? Are you on speed density?
Dont listen to foreskin fred
Old Aug 5, 2017 | 05:30 AM
4G63_Crazy's Avatar
5 Year Member
Nope, haven't swapped map and I'm not in SD. I just ordered Br7es plugs, should get them today..
Old Aug 6, 2017 | 06:30 AM
4G63_Crazy's Avatar
5 Year Member
OK update.. So swapped the spark plugs and did a few pulls, everything was alright, so the spark plugs fixed the problem
Old Aug 6, 2017 | 11:36 PM
For now.
Iridium or platinum plugs are the proper ones as the finer points give a better spark for the same gap.
They'll also last pretty much for ever or until they get another coating of oil.
Even then, all they need is cleaning.
Old Aug 7, 2017 | 12:20 AM
4b11slayer's Avatar
I run bpr8es and change them at every other oil change.
Old Aug 7, 2017 | 01:04 PM
slocho's Avatar
Copper vs irridium is essencially up to you. Ive read numerous posts about either or. Some people use iridium to go longer intervals. Some use copper because they are cheap.. but ultimately the coil packs are what give the quality spark, wires transport the spark, and spark plugs allow it to be exposed at a controlled distance.
just think of the bosch platinum +4.. do you think it really sparks 4 seprate sparks all at once? No, no it doesnt.
N33d45p33d
Oct 14, 2017 01:43 AM
GsrJake
Dec 11, 2012 10:35 AM
IREVO
Dec 24, 2005 04:27 PM
LancerEVOmann
Oct 31, 2004 08:01 PM
rbm3
16
Nov 21, 2003 09:30 AM
