Clutch pedal pulsating
Old Sep 22, 2017 | 10:32 AM
_EVOIXMR_'s Avatar
I have a 2006 Evo IX MR, and Ive been feeling a pulsating vibration on the clutch pedal at the very top where you usual have a little bit of play. I checked under the hood and my slave cylinder rod isnt touching the clutch release fork. Does the slave cylinder have an adjustment or do I need to bleed my system or do I need to replace the slave cylinder.
Old Sep 22, 2017 | 10:40 AM
meckert's Avatar
Bleed it first if there is a concern. I don't believe there is an adj on the slave, there is one at the master.
Old Mar 22, 2018 | 04:27 PM
_EVOIXMR_'s Avatar
Ok so this problem still has been bothering me I haven't drive the car much but the other day bled the slave and still vibration, so I unbolted the slave cylinder and the vibration seem to coming from inside that's making to fork pulsate. Any Ideas what it could be, I really don want to remove the transmission but if I must then I guess I will, any help is greatly appreciated.
Old Mar 22, 2018 | 04:36 PM
2006EvoIXer's Avatar
Can you press on slave cylinder piston and get it to slowly retract inside cylinder?
And what mods do you have? Did you delete balance shafts?
Old Mar 22, 2018 | 05:00 PM
_EVOIXMR_'s Avatar
Yes I can press the slave cylinder piston and it retracts slowly. Only mods are Ams motor mounts, AEM intake, Agency BOV, and a clutch about 24,000 miles ago don't remember what brand. I did not delete the balance shafts.
Old Mar 22, 2018 | 05:12 PM
I'm out of ideas to avoid taking your tranny out.
Old Mar 22, 2018 | 06:49 PM
loch's Avatar
Your flywheel or pressure plate maybe backing off. dont drive it go get it checked
Old Mar 22, 2018 | 10:54 PM
RightSaid fred's Avatar
Driven plate has pieces missing
Old Mar 23, 2018 | 07:15 PM
barneyb's Avatar
It probably doesn't matter much what is wrong, a clutch isn't supposed to wobble.
volkskid
Apr 3, 2008 05:17 AM
Fujilicious
Sep 2, 2007 07:54 PM
EVOLOVE
Jul 4, 2007 05:46 AM
wojtekk
Lancer Troubleshooting
Sep 6, 2006 03:14 PM
woodc
Jun 16, 2005 06:46 PM
