Built Block recommendations
Old Oct 13, 2017 | 05:12 AM
blackline's Avatar
5 Year Member
Originally Posted by Teal2nnr
Whats wrong with an MAP short block? Im currently running one assembled by them.....
how are you liking the block?
Old Oct 13, 2017 | 06:25 AM
2winscroll's Avatar
Originally Posted by Tuxevo
The 4g64 block is a little cheaper and more available. The added displacement would help with autocross as well.
I dont think the 4g64 is more reliable then a 4g63. Anyhow.
You can check out boostin performance. Buschur. Curt brown. Theres a few reputable builders. But if it were my money id hit up buschur if its still the og buschur. Cause hes ritired or retiring.
Nothing wrong with map, just a crap show
Old Oct 13, 2017 | 06:28 AM
Teal2nnr's Avatar
Ive had no issues with mine, but i haven't really pushed it hard (450 whp on pump for a summer). I also haven't had the chance to drive the car in a long time. Its a bit if a story on what happened as to why they had to assemble my motor (i had brought the car to them at the time only for a dyno tune). Anyway, all the machining and balancing was done at a trusted local shop before they had the motor. So basically MAP tore it down and put it back together again using the same parts. However, the motor has been good thus far.......but after looking PAL's build thread, im having second thoughts. Ah well, we'll see what happens. I don't have any oil consumption though.
Typing this from my phone so you'll have to excuse some of the errors.
Old Oct 13, 2017 | 07:51 AM
LetsGetThisDone's Avatar
I've seen too many of their motor's have issues, and then they don't stand behind it. Most of it is machine shop/assembly issues cause by poor machine work. So, you have had an outside machine shop do all yours, and MAP just bolted it together, you're probably fine.
Old Oct 13, 2017 | 11:35 AM
Coqui's Avatar
my current setup is S1 cams, 1000cc injectors, CRBD BBK full, 3in TBE, 70mm TB and Ported mani.
I'm running full bolt ons, s1 cams, 1000cc pte injectors and just went with Buschur built 2.0L...block should be Installed and back on road by end of month
Old Oct 13, 2017 | 11:50 AM
Teal2nnr's Avatar
Ah i see, fair enough. I guess ill see how it goes next year when its pushed.
Old Nov 8, 2017 | 12:20 AM
djbaselle's Avatar
Veteran: Air Force
also running MAP 2.0
Old Nov 8, 2017 | 05:39 AM
Eric SlowEvo8's Avatar
anyone trying to go 2.4? I'm trying to trade for a 2.0 lol
brunz44
Feb 17, 2017 08:56 PM
poon'dEVO
Jan 20, 2015 06:02 AM
dsm25psi
18
Nov 15, 2014 11:53 AM
Evoovasti
Apr 9, 2009 11:24 PM
