Re-sleeving a 4g63
Old Oct 11, 2017 | 11:38 PM
  #31
kikiturbo's Avatar
Originally Posted by Pal215
RightsaidFred is a special character. He is actually a very smart guy, but extremely random and deceptive. Some say he actually has another account on here and that he uses the RightSaidFred
account to troll evom. He may know the right answer to many issues, but chooses to answer them incorrectly. Why? I'm not sure, but evom.net is a brighter and more surprising place with him as it brings a certain comedy to the field.
you should see him on lancerregister..
Old Oct 17, 2017 | 02:21 PM
  #32
dempyel's Avatar
I recently sleeved my block from some heat/detonation damage (hole in piston), no problems in my local machine shop (im from Chile)
I've seen many 4g63 blocks getting sleeved , and seeing 800+whp no problems.
Greetings!
Old Oct 17, 2017 | 02:28 PM
  #33
RazorLab's Avatar
Ironically RED posted some images of sleeving a 4G63 the other day on their facebook page.
He sleeved my 4B11 earlier this year and did an excellent job.
Old Oct 18, 2017 | 08:48 AM
  #34
ineedboostman's Avatar
So when done properly this will handle more abuse than the stock block and can be sleeved over and over again? Also are there o-rings on the sleeves?
Old Oct 18, 2017 | 12:04 PM
  #35
LetsGetThisDone's Avatar
Dry sleeves don't touch water, hence "dry", no orings. Sleeving the block is probably more expensive than snagging a good used one.
As for more abuse, you need to define "more". A 4g63 block can handle a lot of power before needing to be filled..
Old Oct 18, 2017 | 12:44 PM
  #36
Got it doesn't touch a water jacket. Whats the point of using them if it cost that much more to purchase sleeves and machine relative to getting a used block?
Old Oct 19, 2017 | 10:36 AM
  #37
Stronger than a standard block without having to fill the block with concrete or some other block fill.
Old Oct 22, 2017 | 07:59 PM
  #38
Pinknuts's Avatar
I just cracked a cylinder in my car, from what I’ve found you’d be better served to go with another block. Not many people have sleeved 4g63, and it’s not cheap
Old Mar 13, 2019 | 12:08 AM
  #39
Dakota Evo's Avatar
my block is sleeved 580 whp for 3 years
hktrigguy
22
Oct 31, 2016 01:02 PM
evolve_VIII
11
May 9, 2013 09:45 AM
scottsee
Mar 27, 2005 07:42 AM
Go_Lancer_Go
Nov 17, 2004 07:44 PM
