Help 6 speed pops out of 5th gear
Old Nov 26, 2017 | 05:49 AM
icole's Avatar
Yesterday I was driving on a winding mountain road and the car popped out of 5th. Today it happened again, so I put it back in and drove about 1 mile before it happened again. All of my gears shift nicely solid feel no grinding, and easy to get in. Also I almost never use fifth, and really don't use it when I drive hard. I recently rebuilt the transfer case, is it possible, and this is very hopeful, that the shift linkage just needs some adjustment?
Old Nov 26, 2017 | 06:39 AM
Definitely an issue. Im no drivetrain expert, but could be a no. of things. Something simple would be:
  • Worn motor mounts, causing the tranny to twist under acceleration
More severe issues could be:
  • Bent/ damaged shift forks or some other internal tranny issue
Just a thought
Old Nov 26, 2017 | 06:49 AM
icole's Avatar
Unfortunately it’s not motor mounts. I have almost brand new solid aluminum mounts I just drove around some more. If I accelerate hard or coast it stays in gear but when I start cruising I can with my hand on the shifter I can feel it pushing its way out of gear under light acceleration. There is definitely something internal.
Old Nov 28, 2017 | 04:43 PM
Pal215's Avatar
Does it go into 5th cleanly with the car off?
Old Dec 12, 2017 | 09:32 AM
icole's Avatar
It does go into 5th cleanly car on or off. No matter my Shep stage 1 5 spd is on the way.
ezzey
Aug 17, 2014 07:23 AM
byc_panty
14
Jun 8, 2009 09:57 AM
byc_panty
Mar 5, 2009 11:00 AM
82NoMe
Sep 10, 2007 03:01 PM
DCSilvrEvo
Jun 25, 2005 07:38 PM
