Need T-case oil recommendation!
Old Jan 19, 2018 | 01:42 AM
babaz7's Avatar
I have 2 options for t case oil.
1. redline shockproof light
2. diaqueen LSD gear oil sae 90 (part #3775610)
The problem with diaqueen is i have this very old stock left of it atleast 7 years old..and i also think its not enough for the t case ,can i still use it?
I think diaqueen is also discontinued.
So can I go with redline shockproof light ?
Old Jan 19, 2018 | 07:03 AM
LetsGetThisDone's Avatar
I wouldn't do shock proof. Redline 75w140 works great though.
Old Jan 19, 2018 | 11:37 AM
barneyb's Avatar
Gear oil in a can doesn't get old. Dip stick the can and multiply that by the width and depth of the can to see how many cubic inches it contains. Then convert this to quarts.
Old Jan 19, 2018 | 08:47 PM
babaz7's Avatar
I measured it..i have exactly 1 liter of the stuff left.
The t-case can be filled with it but dont know about the rear diff.
I took out the transmission and the t case..would that effect the rear diff? I mean the oil thats in the rear diff shouldn't be drained because i took the front t case out right? If thats the case then I'm good otherwise im in trouble cause I only have enough diaqueen for one of the diffs.
Old Jan 19, 2018 | 09:22 PM
barneyb's Avatar
You gotta enough for one or the other and they don't drain together.
Old Jan 20, 2018 | 12:49 AM
babaz7's Avatar
if the back diff isnt connected to the front one im fine. i will check anyways by opening the fill plug on the diff to see if oil is in there, hopefully its there.
btw mine is a JDM evo 8 so it comes with the ACD/AYC system, the reservoir in the trunk is empty now since i removed the t case, after i fill it up, do i need to bleed the system?
and do the AYC/ACD system use the same ATF SP 3 oil or they have diffrent oils?
Old Jan 20, 2018 | 06:37 AM
aggieEVO's Avatar
Make sure you read this on proper filling. Can't just drain and fill.
https://www.jackstransmissions.com/pages/t-case-filling
Old Jan 22, 2018 | 09:17 AM
silverevo05's Avatar
^ good info
thanks
dueces
May 17, 2017 04:24 PM
foxbat
19
May 13, 2014 07:39 PM
Arsenal4Life
Oct 26, 2013 10:03 AM
DONNOD
Apr 1, 2013 08:58 PM
