Need help building 2.0LR or 2.2LR Evo 9
Old Jul 27, 2018 | 07:18 AM
Abacus's Avatar
I would 100% go with a 94mm crank unless you had enough transmission to shift well at 9500rpm+ . A bigger crank is just going to create a larger powerband and make the car more enjoyable .
Old Nov 5, 2020 | 05:57 AM
justboosted02's Avatar
Originally Posted by heel2toe
From what I've been told the 156mm 2.2 using a 63 block does not hold up as the pin is too high and cuts into an oil ring.
The latest and greatest motor these days is a 2.2 consisting of a 94mm crank 153mm rods and custom height pistons. My block is sitting at ER currently and thats the motor I'm going with.
See here: https://englishracing.net/collection...00-short-block
does anyone have any first hand experience with the 94mm crank/ 156mm rods? I get that its not an ideal piston compression height but there are a few manufacturers offering this combo and I wouldn't think it would be offered if it was truly a bad setup.
Old Nov 5, 2020 | 08:52 AM
LetsGetThisDone's Avatar
Yes. Don't do it.
Bad products are offered for sale all of the time. MAP stock frame turbos come to mind. Junk Korean/Chinese tires.
Idk why the 94/156/4g63 combo is so appealing. Its repeatedly said in this thread to not do it... Additionally, the 94/150/4g63 revs to 9500 just fine anyways. Everyone trying to run a longer rod for no reason. Hondas run a rod ratio of 1.55:1 from factory and rev to 11k... Its not ALL about rod ratio.
Old Nov 16, 2020 | 11:12 PM
ConEvo's Avatar
Yes. Don't do it.
What about a 2.2 (94/156/4g64) combo? Do you think is a good choice? I have a 4g64 (100/156) combo and I rev to 8.500. I was thinking if it worth switching to 2.2 4g64 option to rev at 9.500. Also, I wanted to ask. If I switch to 94mm from 100mm, is the piston/rod combo compatible with the 94mm crank or do i have to buy new ones?
Old Nov 17, 2020 | 09:22 AM
I have that in my car, you can use the same rod, but you'll need a different piston with appropriate compression distance. It's a really good setup. Mine is extremely smooth with good balancing work from my machinist and an ATI damper.
Old Nov 17, 2020 | 04:35 PM
hutch959's Avatar
whats everyone think about a 94/156/4g63
It was a joke!... Im sober
Old Nov 17, 2020 | 11:02 PM
ConEvo's Avatar
My current setup is 4G64 2.4 long rod, and i was thinking if I could only swap the crank to build a 2.2 4g64 destroker I would probably do it. But if i need to buy pistons too, I have to rebuild the engine from beginning and that would be push me back. I just want that 1.000+revs to push the turbo to its limits, broaden the powerband a bit more and also push the gears even further
Old Nov 18, 2020 | 10:31 AM
You would either need pistons, or 159mm rods. But if you do just rods, the shorter stroke will lower your compression ration by about .6-.7:1. If you currentl have a 9:1 motor it'll be in the low 8's, a 10.5:1 will end up in the high 9's.
silentkiller
20
Mar 29, 2015 05:23 AM
jamie_v1
Mar 27, 2011 07:54 PM
4g63 gsr
Feb 21, 2010 02:54 PM
bigleadfoot
Sep 18, 2008 08:20 AM
antos
Feb 9, 2006 06:04 AM
