Low oil pressure problems
Old Mar 29, 2018 | 11:49 PM
BeatboxingFTW's Avatar
Hello, i recently started having some oil pressure problems at wot and at idle, when i go to like 6-7k rpm with NO LOAD the oil pressure is good at around 90psi but as soon as i get into boost it drops to 60psi, it only happens on 1st and 2nd gear and by 3rd it recovers, and at idle i have realized that before this happening i was sitting at around 30psi and now at idle im at around 20-10psi, my compression is really bad at 120 120 105 145, also i believe im pushing a little bit of water since after a hard run (like 1-4th gear) my coolant overflow gets completely full and there is some bubbling
(by the way oil pressure gauge is the one on the middle)
What do you guys think? head gasket, oil pump, bearings ????
Any help is really appreciated
Old Mar 30, 2018 | 08:27 AM
2006EvoIXer's Avatar
Sounds like head gasket to me. It's possible head gasket leak is causing all your problems. Don't wait too long to fix because you can lose some bearings if you wait.
Old Mar 30, 2018 | 08:30 AM
Upgrade your head bolts while you're replacing your HG. Sounds like your head is lifting under boost. Check your head and block for warpage when it's off.
Old Mar 30, 2018 | 10:07 AM
Ok what head bolts you recomend? Im running 41psi and i have l19 bolt, should i go get the custom age 625? And also should i get a oem evo headgasket or go for aftermarket?
Old Mar 30, 2018 | 12:04 PM
OEM HG. Before you remove your L19 nuts, try torquing it down to see if any cam loose. Start at 70 ft-lbs on each and work your way up. I'm surprised you got lift with those arp head studs.
Old Mar 30, 2018 | 02:19 PM
RightSaid fred's Avatar
More than one problem.
Headgasket, rings and fuel pressure.
https://www.evolutionm.net/forums/ev...rich-help.html
Old Mar 30, 2018 | 02:40 PM
Oh wow, that's really rich. If the built motor has been running like that for a while, there could be worn piston rings and cylinder walls.
Do you drive your car daily? Or let it sit weeks at a time?
Old Mar 30, 2018 | 03:15 PM
Looks like you down shifted by mistake in that 1st video.
Inprogress
May 15, 2014 06:43 AM
Inprogress
May 15, 2014 06:42 AM
hiboost2.0
16
Jan 2, 2014 08:10 AM
Bullett
North Texas Evo Club (NTEC)
18
Feb 26, 2012 05:39 PM
jbigelow
14
May 3, 2005 08:46 AM
