Tuner right or wrong
Old Apr 26, 2018 | 09:25 PM
AWD Problems's Avatar
Veteran: Army
So i have 03 evo stock head stock block
fp red turbo
kelford cams
450 walboro with dble pumper
1050x id inj3ctors i have 1700cc on hand to switch over
aem fuel rail
fuel labs fpr
went to get a tune on e85, was told that the car wouldnt be able to handle safely since injectors are to much.
then he tells me i can run e85 on the 1050x injectors.
instead of just questioning him i decided to stick with pump gas on the 1050x.
just want to know if the tuner was correct . Or should i have gone with someone else
Old Apr 27, 2018 | 11:06 AM
fp red turbo
kelford cams
aem fuel rail
fuel labs fpr
Pretty sure a tuner can scale those 1700cc to work just fine. Its done all the time
Hey, Im E85 tuned & on the 71HTA turbo & im out of injector using the RC1000's.
Seems like a tuner more familiar w/EvO's & E85 is needed
Old Apr 27, 2018 | 11:20 AM
Pal215's Avatar
Yup, tuner is wrong. He must not feel comfortable scaling larger injectors. Also, you'll max out those 1050cc's with an FP Red on E85 fairly quick.
Old Apr 27, 2018 | 11:22 AM
2006EvoIXer's Avatar
1050cc isn't enough for Red on E85. But double 450lph pumps are overkill. Lol.
Old Apr 27, 2018 | 11:27 AM
On stock block, Red will make enough torque to break your rods and vent your block. Make sure you find a tuner who knows to keep torque down.
Old Apr 27, 2018 | 04:40 PM
LetsGetThisDone's Avatar
A stock turbo can do that. Controlling torque is a given with the stock motor.
OP, find a new tuner. It should not be an issue to tune 1700's for the right tuner.
Old Apr 28, 2018 | 11:27 AM
jspecteggy's Avatar
fp red turbo
kelford cams
aem fuel rail
fuel labs fpr
I am in SATX as well, I was just tuned on E85 and am running FIC 2150's. Sounds like the tuner you are using does not know how to scale injectors. Pm me if you need anything.
Old Apr 28, 2018 | 11:41 AM
kaj's Avatar
kaj
On the bright side, I have a set of FIC 1450s that I recently got back from RC after cleaning/testing. I'd be willing to trade you straight across, as long as you don't mind shipping first so I have no down time. They are overkill for my application, so looking for 1050s, assuming yours are high-z.
Old Apr 28, 2018 | 10:05 PM
codgi's Avatar
As others have said, find a competent tuner that knows these cars and is familiar with E85. That one just isn't.
Spooldyou
65
Nov 10, 2006 07:18 PM
Vivid Racing
25
Mar 20, 2003 10:44 AM
